Hissing sound from engine. Is this normal?
Old 21 Jun 2011, 10:17 pm
HYE_PTC's Avatar
Default Hissing sound from engine. Is this normal?
Wasn't sure if this is normal engine noise, I haven't had the car too long. But I hear like a hissing noise when engine is on. Could it be exhaust leak? Car drives normal.
2002 LE model - 80k miles
Old 21 Jun 2011, 11:01 pm
Dill's Avatar
Default Re: Hissing sound from engine. Is this normal?
Try looking for any cracked or damaged vacuum hoses, particularly from the UIM to the engine.
Take off your modesty cover, (says dohc 16v) its pretty easy and turn on the car and listen around.
Commonly pts in our year model start to have wear on the vacuum lines. In fact tomorrow ive got to replace one on the right side of my uim going into my engine, ends are starting to deteriorate.
Easiest way is to run the car, lift the hood and listen around and squeeze hoses in the sound area looking for cracks or nething odd
Old 23 Jun 2011, 02:57 pm
HYE_PTC's Avatar
Yes, the hose that connects to the manifold and valve cover is cracked on the ends. Thanks for the tip.
Old 24 Jun 2011, 04:36 pm
What is a UIM?
Old 24 Jun 2011, 05:31 pm
Send a message via MSN to jccc
yes this is fine as your pt sounds like its got a special edtion viper engine
lol
Old 24 Jun 2011, 07:33 pm
Originally Posted by mperkins37 View Post
What is a UIM?
Upper Intake Manifold
Hissing sound hammeri Tech & Performance Forum 4 07 Oct 2012 05:39 am
Oil-Engine Light, Squeal sound at start up firebirdcabrio Tech & Performance Forum 3 26 Dec 2010 07:20 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
Weird sound from engine? Scrathy Tech & Performance Forum 1 01 Sep 2009 12:34 pm
CRICKET SOUND FROM ENGINE ? JGN General PT Cruiser Discussions 11 05 Aug 2004 07:04 pm
