Water Leak From Under Passenger Side Dash
Old 31 Jul 2011, 02:48 pm
jwlast's Avatar
Default Water Leak From Under Passenger Side Dash
Looking for some help. Got an intermittent water leak from under the passenger side dash. Oddly, only leaks in occassional trickles, clear water, no antifreeze. Seems to be dripping off the fan pictured. Any clues the source?
TIA
JT
Old 31 Jul 2011, 03:18 pm
Default Re: Water Leak From Under Passenger Side Dash
Does is happen when you are using the AC? if it does, it has to be water condensation from the AC evaporator. It supposed to have a hose to drain it outside, but probably dirt clogged it. You will need to get under the car and try to find it and stick a wire or something to unclog it so the water drains out.
Old 31 Jul 2011, 03:27 pm
rcktpwrd's Avatar
I agree, probably a clog in the drain line. It is on the firewall, under the hood, roughly in the center and hangs down about a foot or so... Kinda looks like a vacuum line that isn't connected to anything...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 31 Jul 2011, 04:11 pm
jwlast's Avatar
Thanks guys, I think you hit the nail on the head. Does seem to be ac related. Now all I got to do is find that drain line.
JT
Old 07 Jun 2014, 01:47 pm
I just posted regarding the same problem with my car! Thanks for the info! Can someone please send me a picture of what the a/c drainage hose looks like?
Old 07 Jun 2014, 01:51 pm
boonie2's Avatar
Cant miss it , its should be the only openended hose under there on the pass. side
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 07 Jun 2014, 02:04 pm
I did see a hole that had a little water coming through it, but it looked to be part of the frame, not a hose. This would be found underneath the car, right? Please forgive my ignorance, normally, my husband would be doing the mechanic work, but he's out of town and I kind of need my car working.
Old 20 Jun 2014, 06:55 pm
Open the hood an look towards the rear of the engine compartment on the passenger side. There is a small 90 degree tube there
Old 20 Jun 2014, 07:42 pm
She found it..
Water draining into passenger floorboard
Got A Water Leak! bados General PT Cruiser Discussions 16 10 Apr 2017 09:05 am
Passenger Side Oil Leak rleey07 PT Cruiser Convertible Forum 3 18 Jan 2010 09:54 pm
Water leak! PattiV General PT Cruiser Discussions 2 21 Jun 2009 03:24 pm
Passenger side airbag pt-banjeral Tech & Performance Forum 6 13 Jan 2006 09:36 am
wtb passenger side armrest josheypt Interior Accessories Forum 0 06 Nov 2005 03:30 pm
