multi-function switch
Old 14 Sep 2011, 07:05 pm
Default multi-function switch
is there any way to test the multi-function switch.my dash lights,tail lights,radio wont dim and chime will not go off when lights are on and the ignition switch is off .ive read all i can and i think this is my problem. can anyone help
thanks in advance
Old 14 Sep 2011, 07:51 pm
compdr59's Avatar
Default Re: multi-function switch
You would probably need to read a schematic to troubleshoot. The electrical components in our cars are not the best. I had to replace mine when the fog lights stayed on and killed my battery. You can buy from Advanced Auto Parts. Try this link for a discount, if it doesn't work I can email you one.....
Welcome to Advance Auto Parts - Exclusive Friends & Family Offer
Original Owner 135k
Old 14 Sep 2011, 08:30 pm
WolfmanG's Avatar
you might want to be careful with tho's after market parts, especially electronic components. Our PT's don't like them.
-Danny Wolfman G
Old 15 Sep 2011, 06:10 am
I read somewhere that the one Advance Auto sells is the same part number as MOPAR. The post had a side by side pic
edit: It was Auto Zone not Advance Auto. Here's the linky: http://www.srtforums.com/forums/f123...r-part-559953/
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 15 Sep 2011, 08:02 am
That's only true of sensors. I got a MF switch from RockAuto on my daughter's GT - it's been fine.
Old 15 Sep 2011, 08:30 pm
thankx guys i guess i'll go buy one and see what happens,i'll let you know the results
Old 15 Sep 2011, 10:00 pm
WolfmanG's Avatar
ok thanx for the clarity. I knew that was true for the sensors but wasn't to sure about the mf switch. I was hoping someone would come in and correct me.
-Danny Wolfman G
Old 17 Sep 2011, 07:10 pm
ok people heres the scoop.i replaced the multi switch an it worked .i got it from auto zone and it an original part.then after i replaced the switch ,i opened th bad one ,i thaught it was going to be full of relays,diodes and other stuff ,but all it is ,is a curcuit board and sliding contacts.on mine one of the contacts seems to have over heated and got stuck on the spring.so i got it loose and now it spring like it should .iwill be testing it next sat (my only day off) and let you know if it works
I need this multi-function switch... anyone? Rowdy Classifieds: Want To Buy 12 07 Apr 2017 10:34 pm
how to install multi-function switch? Juicy General PT Cruiser Discussions 44 14 Apr 2014 01:13 pm
Multi Function Switch missinglink Tech & Performance Forum 7 11 May 2011 07:47 pm
multi function switch problem neworder18 Tech & Performance Forum 4 10 Mar 2010 04:35 pm
WTB - Multi-Function Switch ucantcme Classifieds: Want To Buy 11 13 Oct 2008 03:03 pm
