Oil coming out of tailpipe
Old 16 Sep 2011, 05:34 pm
Default Oil coming out of tailpipe
I have a 2007 PT Cruiser. It is now leaking oil out of the tail pipe. Are there any recalls on this and what could be the problem. How much would it be to fix it.
Any help would be great! Is this a bad problem? I only have a 58k on this car.
Old 16 Sep 2011, 05:47 pm
Default Re: Oil coming out of tailpipe
There are no recalls for something like that. If you Google "oil out the tail pipe" you'll find a dozen answers and most aren't good. Overfilling the oil pan or maybe a bad ring or two. The big question is: Are you sure it's oil. Condensation mixed with the soot in the tailpipe will definitely look like oil. If you aren't running bad or smoking out the tailpipe, it might not be oil.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 16 Sep 2011, 06:04 pm
Thanks, it is running bad so it is most likely oil.
Old 16 Sep 2011, 07:32 pm
fabreezai's Avatar
As Crewzin said, It could be many things. First of all, what kind of PT is it (base, limited, turbo, standard, auto?) It could be bad rings on the pistons, valve guides or valve seals, head gasket, etc. A few thing to look for would be: have you been having to add oil because its low?, does it constantly smoke when running? Is there oil in the coolant or coolant in the oil? was the oil ever over filled?, have you owned it since new? If used, did you get any maintenance records with it? Any or all of this info would help. For starters I would pull the plugs and take a look at them, they will give you a clue as to what the engine is doing. Post some pics if you can of them.
Cheers!
Old 17 Sep 2011, 08:56 am
UptownSport's Avatar
All as said above-
To get oil out of tailpipe you'd need an immense amount of oil, muffler acts as a 'trap', has a lot of volume. I'd have no idea how raw oil and the cat would interact.
Your car would likely blowing the blues, big time.
Perhaps it's running really rich?
Grinding/rotating noise coming from left side of car when coming to a stop...help? quietcharm23 Wheels, Tires, Suspension 3 10 Apr 2011 08:43 pm
Fan not coming on ironwill22 General PT Cruiser Discussions 34 06 Jan 2009 08:00 pm
Tailpipe cleaning PTucker The Detail Shop 2 01 Feb 2004 12:26 pm
Tailpipe Cutouts Mean Green Turbo Performance 7 18 Jan 2004 08:07 pm
3" exhaust turbo to tailpipe tthrift Turbo Performance 8 25 Aug 2003 01:01 pm
