Low idle stall issues.
Old 17 Oct 2011, 01:46 pm
Default Low idle stall issues.
i have a 2002 PT Cruiser with 215,000 miles on it. Recently when I started it,and drove it, when the idle would get low, it would die. The only way i can describe it is it reminds me of an old car i had, my dad would adjust the carb because the idle was so low it would die.
it doesn't happen when i'm driving, just at a stop, or when starting it. Its very random, sometimes it happens 10-15 times while driving in town, to never doing it at all. Our bonehead mechanic can't find out the problem, so his solution was to try and replace the fuel pump with modular. (which we did, and it really hasn't made much of a difference)
Any suggestions? i love my car, so i want to get her fixed, but we have no clue where to go or what to do! HELP
oops ETA: there is no check engine light, mechanic hooked the codes thing (sorry can't think of the word) and nothing came up
Old 17 Oct 2011, 02:15 pm
rcktpwrd's Avatar
Default Re: Low idle stall issues.
When was the last time spark plugs and wires were changed? Had the throttle body ever been cleaned? It could also be a problem with the EGR system.
At 215,000 miles you should also be doing the timing belt/water pump for the second time, if that hasn't been done yet...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 17 Oct 2011, 03:32 pm
Agree with all of Joel's ideas in his post.
Also - Idle air Controller - bolts to back of throttle body - should be taken off and checked/cleaned.
Throw some Lucas fuel injection cleaner in the gas.
Old 17 Oct 2011, 05:10 pm
thank you so much for the ideas, we're on it now.
the timing belt and water pump are new. the plugs and wires were just done, and oddly enough, the car started having the issue about 2 weeks after they were done. does that info work here?
oh, and yes, the throttle body was cleaned. It improved a bit after that, but still has the issues. Just not as much.
Old 17 Oct 2011, 06:52 pm
rcktpwrd's Avatar
Do you know what the spark plug gap was set to? It should be 0.040"
I think I would look at the EGR system.
Joel
www.rcktpwrd.com
Old 17 Oct 2011, 07:25 pm
hub is going back to the mechanic who did the plugs and they are going to check out the plugs.
So, speaking as an uninformed girl, i notice when people talk about EGR, there's always some mention about spark plugs. Coincidence? or could that be the real problem to begin with. As i may i have said, it started w/in 2 weeks after the plugs/wires were replaced.
Old 17 Oct 2011, 09:56 pm
rcktpwrd's Avatar
The egr is exhaust gas recirculation, its an emissions device.
Joel
www.rcktpwrd.com
Old 18 Oct 2011, 07:29 pm
update:
hub cleaned throttle body. Then he pulled hose off the EGR valve, started the car, idled up, and put the hose back on, and then it idled back down. He looked inside the hose, it looked a little moist, and a very strong smell of gas. but it was dry and wasn't leaking fuel.
anyone have anything?
Old 19 Oct 2011, 08:21 am
From your description, sounds like he played with PCV (Positive Crankcase Ventillation) not EGR. The PCV valve should be replaced - I think it's only like $15.
EGR shows up in here:
Spark Plug Guide
Old 22 Oct 2011, 11:51 am
Spark Plug Guide
thank you for the link. hub is going to do this next week. I love my car, and it kills me that its having problems! I'll let you know how it turns out.
Rough Idle, Warm A/C, and Cam Sensor Issues! rfurey15 Tech & Performance Forum 6 31 May 2012 10:54 pm
High Idle and Cooling issues shadowsnkx Tech & Performance Forum 0 06 Sep 2011 09:55 pm
05; air,idle and now overheat issues Treedweller General PT Cruiser Discussions 8 16 Jul 2011 04:50 pm
2007 GT - Rough idle & Stall RainWind General PT Cruiser Discussions 4 27 Mar 2009 12:21 pm
Idle Issues CoryMartelca Tech & Performance Forum 2 23 Oct 2007 08:04 am
