'01 PT Limited Edition Won't Start
Old 18 Oct 2011, 05:11 pm
Default '01 PT Limited Edition Won't Start
I have and 01 Cruiser that last night as I was making a turn to the right, it shut off.. It will turn over but not run.. we charged up the battery.. everything works, lights, radio ie.. it just acts like it wants to run but won't turn over.. any suggestions or help?
Old 18 Oct 2011, 05:20 pm
Default Re: '01 PT Limited Edition Won't Start
How many miles on her? Sounds a lot like a broken timing belt.
Old 18 Oct 2011, 05:30 pm
113000 or so.. we replaced the timing belt about 3 weeks ago.. it has run fine since last night..
Old 18 Oct 2011, 05:32 pm
When the timing belt broke a few weeks okay.. I had nothing.. it wouldn't even turn over.. now it tries to turn over, just won't run..
Old 18 Oct 2011, 05:44 pm
Susan.
Did the engine light come on? That means a sensor saw a fault and sent a message to the computer. We need to know that fault code to try and help.
How to retrieve fault codes.
If no engine light, the two things you mostly need to get the engine going are fuel and spark. The fuel pressure needs to be tested (at the end of the fuel rail) and you need to see if spark is getting to the plugs.
You might want to try the easiest thing, get a jump start from a good battery. You might have lights and radio but they take little voltage to work. To start the car you need nearly a full 12 volts. it could be that your alternator or battery are on their last legs and you just ran out of power.
Old 18 Oct 2011, 05:50 pm
Okay.. I'm a bit of a blonde somedays.. the engine light is the yellow engine symbol in the bottom left?? Or the red light on top of that same cluster window? The red light up on top is what I remember to have come on after it shut off..
Old 18 Oct 2011, 05:55 pm
The fault light is the yellow engine symbol in the black oval. That red symbol is either the battery or the oil light.
Edit: Whatever: try that link I put in my answer and see if there's any fault codes that might help up. If there's no faults it will say "done". If there's a fault, it would look like this P0041 or P0340 or another set of numbers.
Old 18 Oct 2011, 06:10 pm
I just checked it and it said "done" I guess it could be a number of things from the coil pack to a relay..
Old 18 Oct 2011, 06:13 pm
The coil pack which is a very good part and very very seldom gives a problem, or a relay will give a fault code. Start with the jump start from a good battery, that will narrow it down if it's an electrical fault.
Old 18 Oct 2011, 06:16 pm
It was on a battery charger and it wouldn't work.. is that the same as jumping from a good battery??
Just got a new 2003 limited edition pt cruiser Tyler General PT Cruiser Discussions 9 18 Feb 2011 01:07 am
01 limited edition or 03 GT? Dub General PT Cruiser Discussions 9 14 Dec 2010 08:34 pm
Lower springs for '02 Limited Edition missingwhatsnear Wheels, Tires, Suspension 2 19 Feb 2009 09:14 pm
18' Front / 20' Rear 02 Limited Edition reeseque3 Wheels, Tires, Suspension 12 09 Jan 2009 07:53 pm
No longer a Limited Edition... AndyKay Exterior Accessories Forum 7 29 Sep 2003 08:24 am
