BOTH HEADLIGHTS NOT WORKING
Old 03 Dec 2011, 06:07 pm
Default BOTH HEADLIGHTS NOT WORKING
Hi guys, Im a new member here and am having a serious problem with an 06 non convertible, 4 cyl. Both of the low beams do not work but both high beams do. Turn signals and everything works. Car does not have fog lights. Im thinking it might be the bad combination switch but just wanted to get a second opinion. I read that there weren't any relays hooked up to the lights so just wanted to get some input. I tested both high and low beams with a multimeter and got 12V on the high beams when they are on but only .3V on the lows when they are on.
Old 03 Dec 2011, 08:38 pm
Default Re: BOTH HEADLIGHTS NOT WORKING
is the fuse is okay?
Old 03 Dec 2011, 11:14 pm
I believe so . Does anyone know which fuse number it is by any chance ?
Old 03 Dec 2011, 11:30 pm
I'm assuming that the fuses and wires are fine since its getting at least .3V. so theirs something their even though its almost 0.
Old 04 Dec 2011, 02:54 pm
you can actuly have A fuse blow and show voltage but It cant carry currant. change it and see if the voltage comes up if it doesnt it would be looking at a MFS.
Old 04 Dec 2011, 04:40 pm
Fuses are all good so I'm assuming its got to be the mfs. Correct?
Old 04 Dec 2011, 04:44 pm
thats right where I would be looking.
Old 14 Dec 2011, 12:11 pm
probably a stupid question but would touching both the positive and negative terminals at the same time cause the switch to burnout
Old 14 Dec 2011, 12:38 pm
Tell me you didn't do that. No, the MFS probably wouldn't burn out because of that but one or more of the multi-fuses could have blown. Since yours is an 06 and they changed the electrics, I can't tell you which to look for. There are a number of them labeled IOD which is what I'd tell you to look for in the older models. Look for other items that aren't working like power outside mirrors, moon roof, windshield wipers. That would prove it's a multi-fuse. Is the car working right? Hopefully the computer didn't take a hit.
Wait a minute; touching positive and negative terminals with what?
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 14 Dec 2011, 12:42 pm
a wrench. i was replacing the multiswitch so i disconnected the battery. plugged the switch in and it worked fine. everything was working. i just hooked up the battery terminals without bolting them on to tight. low beams, high beams, turn signals everything. but then i went tighten the terminals and i was tightening the negative and i accidentally hit the positive terminal while the wrench was still on the positive and it caused a spark. then after that the lights went back to being themselves with everything working except the low beams.
Headlights and door locks stopped working? CruiserDan Tech & Performance Forum 27 15 Jul 2015 01:50 pm
Headlights and door locks not working!!!! mmnester Tech & Performance Forum 6 17 Jun 2014 02:58 pm
Headlights, keyless entry & instrument cluster lights not working RTCruiser General PT Cruiser Discussions 2 06 Jul 2010 09:13 pm
headlights and power locks stopped working now car wont start nccaneskerr Tech & Performance Forum 8 14 Jun 2010 07:41 am
HEADLIGHTS NOT WORKING ON OUR 2001 P.T. CRUISER brodas3 Tech & Performance Forum 1 06 Jan 2010 06:13 am
