2001 power steering fluid?
Old 18 Dec 2011, 10:07 am
Default 2001 power steering fluid?
I can't find anywhere in the owners manual what kind of power steering fluid to use in my 01 pt cruiser. Thanks!
Old 18 Dec 2011, 10:15 am
Default Re: 2001 power steering fluid?
Same as your automatic transmission: ATF+4
Old 18 Dec 2011, 01:47 pm
rcktpwrd's Avatar
Not in the '01 they use power steering fluid.
Get Chrysler approved fluid at the auto parts store.
Joel
www.rcktpwrd.com
Old 18 Dec 2011, 02:07 pm
Excuss me, I've been using the ATF+4 for at least 7 years even since my OEM power steering unit failed and I put in a new one.
Old 18 Dec 2011, 02:54 pm
I am attaching an Aug, 2003 Chrysler technical service bulletin.
Apparently 2001 model year PT Cruisers were "delivered from the factory with MS-9933 power steering fluid".
The technical service bulletin revises the previous practice and says one "should use ATF+4 (replaces MS-9933)"
Old 18 Dec 2011, 08:39 pm
rcktpwrd's Avatar
My car has yellow colored power steering fluid from the factory, I would not mix that with atf+4. If the system was completely drained for whatever reason then that is a different story.
Joel
www.rcktpwrd.com
Old 18 Dec 2011, 09:44 pm
Definitely do not mix the two different fluids.
From the ptdoityourself.net site
"You won't find any information about which power steering fluid to use in the 2001 owners manual, however it does say NOT to use the ATF+4 transaxle fluid. I don't have a service manual for that year, so I'm unable to check the recommendation there.
The latest power steering TSB issued in August 03 indicates that the “factory fill” for the 2001 was MS9933 as indicated by the Chrysler rep, however under the TSB, the “approved service” power steering fluid is MS9602. This indicates that you should use MS9933 to top-off the OE factory fill, but when replacing the fluid DC would use MS9602.
Mopar ATF+4 automatic transmission fluid (MS9602) is now being utilized because it provides superior performance at both low and high temperatures.
The TSB states that the bulletin supersedes owner's and service manuals for the vehicles listed (2001 PT among other makes and model years) that may state to use MS9933 in the power steering system, and that may state not to use automatic transmission fluid in the power steering system.
The “factory fill” for the 2002-2005 model years was MS9602 and the “approved service” power steering fluid is MS9602.
The 2006 service manual states that the recommended fluid for the power steering system is Mopar Power Steering fluid + 4 or Mopar ATF+4 Automatic Transmission Fluid. Both Fluids have the same material standard specifications (MS-9602). Mopar ATF+4 (and Mopar Power Steering fluid + 4), when new, is red in color. ATF+4 is dyed red so it can be identified from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not an indicator of fluid condition. As the vehicle is driven, ATF+4 will begin to look darker in color and may eventually become brown. THIS IS NORMAL. ATF+4 has a unique odor that may change with age. Consequently, odor and color cannot be used to indicate the fluid condition or the need for a fluid change."
Old 14 Nov 2013, 09:48 am
whiteclaw's Avatar
I know this is an old thread, but still useful. I am currently trying to rule out problems and just checked mine to find the damn thing is empty lol.
So I'm about to buy some to just rule out if this is the cause of my issue.
Question is, can I use this transmission fluid, it's not gonna mess up my car anymore than it is, is it?
I read here to use it, but then looked in my book which says do not. However, I would take any of you experienced peoples word over what may be an outdated recommendation from an old manual.
ATF+4 or to not?
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
Old 14 Nov 2013, 09:54 am
ATF+4 or to not?
Need to find the cause for this. They don't work very well without it.
Old 14 Nov 2013, 09:59 am
whiteclaw's Avatar
well Im wondering if its ever been refilled now since 2001. I have had the car coming up 2 years now. And I will admit, I've never peeked in the power steering to check it. I always check fluids, the coolant engine oil, every now and then the tranny. Not sure why I never checked that one. let it be a lesson to anybody else out there.
Even if it isn't the cause of my other issue, it still needs filling up. Just wanted to get an idea what people suggest. Being in the UK, we get different names for stuff. I just checked halfords website, and all they all say is ATF fluid, no damn numbers next to them or anything.
just to add, the trace amounts of the fluid is like a green/yellow colour. Looks green on the bottle rim but sort of yellow when i checked on paper. Ain't it supposed to be a reddish colour? I really dunno. This is just an eye opener for me. I can't stop reading around now about the whole engine.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Power Steering Fluid Smell lilfoot General PT Cruiser Discussions 1 11 Mar 2011 12:41 am
Power Steering Fluid ptal Tech & Performance Forum 4 05 Mar 2010 09:40 pm
Power Steering Fluid jmack General PT Cruiser Discussions 12 25 Dec 2008 11:55 am
Gasoline and Power Steering Fluid DIYPTGUY General PT Cruiser Discussions 11 29 Nov 2008 01:47 am
TSB on Power Steering fluid? PTGT Redman Tech & Performance Forum 10 31 Mar 2004 06:42 pm
