Springs
Old 31 Dec 2011, 07:47 pm
Default Springs
1111111
Old 31 Dec 2011, 08:29 pm
Default Re: Springs
Could be wrong but from what I've been reading, it's not likely to be your springs but bad bushings, ball joint, or tie rods.
Old 31 Dec 2011, 09:19 pm
SCBluePT's Avatar
Default Re: Springs
It could also be the rubber isolator pads that go on the top and bottom of the springs.
Old 01 Jan 2012, 12:32 am
Default Re: Springs
Ditto, especially in the rear. Sometimes they are left out, when that happens they rub and squeak like crazy.
Old 01 Jan 2012, 12:55 am
Send a message via AIM to srebik Send a message via MSN to srebik
Default Re: Springs
The way yoy make it sound.....you put lowering springs on your vehicles, correct?
or am I misunderstanding?
assuming you have put lowering springs on the vehicles.....
when you put the springs in did you get some shocks/struts to go with the springs or just used the old ones?
I want to say struts/shocks that are/were made for oem springs and have gone out.
it is entirely possible that its some bushing/rubber piece that has worn down enough to cause something to rub thus squeak though.
2003 Dark Blue Non-Turbo Pt Cruiser w/ 5 speed
Old 01 Jan 2012, 11:30 am
Default Re: Springs
The only time I hear them is going up the curb sort of thing going into the drive way, or a speedbump, other than that, they are quiet
Old 01 Jan 2012, 12:24 pm
Default Re: Springs
It sounds like sway bar bushings to me. Did you use plenty of grease when you put the Eibach sway bars?
Old 02 Jan 2012, 09:03 pm
Default Re: Springs
I will take a look at that, thanks
Springs ! 1lowufo Classifieds: For Sale/Trade 16 07 May 2010 05:29 am
Need help with Springs... RobertHD Tech & Performance Forum 0 26 Apr 2010 02:20 pm
springs ???? Jimbo Wheels, Tires, Suspension 4 25 Feb 2004 07:51 pm
Help please/ springs turbomangt Turbo Performance 3 23 Feb 2004 10:26 am
BTG springs ceaesq Turbo Wheels/Suspension/Handling 5 31 Jan 2004 03:49 am
