harmonic balancer
Old 01 Jan 2012, 08:07 am
Default harmonic balancer
Hi Guys
I have been trying to source a vibration problem on my 2001 2.0L PT. I have posted a couple of time before and still trying to track this down.
I notice a few postings talking about a harmonic balancer. Can someone explain what this is?
I have checked, as best I can, the upper and lower torque struts and they seem OK, no signs of cracking, also the top strut is adjusted to 4.7".
Vibration is there all the time whilst driving but worse when pulling away or accelerating. Seems to be related to revs rather than speed or road condition.
Old 01 Jan 2012, 11:57 am
Default Re: harmonic balancer
The 4 cylinder engine in your PT delivers a power stroke every 180 degrees of crankshaft rotation. Since the power application is not smooth but rather in pulses, the harmonic balancer, mounted on the nose of the crankshaft, helps to dampen out these pulses and thus make life easier on the crankshaft.
A harmonic balancer can fail...usually it is a matter of the rubber deteriorating. However, you may or may not notice if it has failed.
Old 01 Jan 2012, 12:26 pm
UptownSport's Avatar
Right Carl! You could simply look at it, you'd notice failure.
Flexplate to clutch / torque converter bolts can come loose.
You could pull inspection cover (PT has a lot of brackets there, IIRC) and look.
So engine makes the vibes even when revved in neutral?
harmonic balancer (or what ever yall call it) mdskinner731 Tech & Performance Forum 4 16 Nov 2011 04:25 pm
harmonic balancer mdskinner731 Tech & Performance Forum 10 15 Sep 2011 09:04 am
harmonic vibration rszappa1 Wheels, Tires, Suspension 17 15 Feb 2006 11:39 am
A solution to the "harmonic drone" problem Gary04GT General Turbo Discussions 12 19 Jun 2004 10:29 am
