Need Help Asap!
Old 01 Jan 2012, 01:11 pm
Default Need Help Asap!
111111111
Old 01 Jan 2012, 01:27 pm
Default Re: Need Help Asap!
I don't have the Turbo but on that picture entitled "where does this go" it looks like you broke the end off that connection on the stationary pipe. Maybe that's where the hose you holding goes; on the piece that's broken off.
...and on the picture entitle "does the tips come out. YES, it should, try to get a drop or two of oil/penetrating fluid bewteen the plastic end and the rubber hose. Twist the tip slowly both ways and work the tip out of the hose.
Old 01 Jan 2012, 04:19 pm
That came from the breather element, the one that attached to the OEM box, nothing is broken YET!
Old 01 Jan 2012, 07:37 pm
I warm up my hoses with a hair dryer before disconnecting so they swell just a tiny bit. If I'm adding new, I heat up a bowl of water and soak the ends in it to warm them up before adding new.
Old 02 Jan 2012, 01:04 am
Think I have it figured out. Am I on the right path?
This picture shows in green where the hose went stock, went underneath stock tubing. I think it goes where the yellow arrow is, to the side of the new pipe. It is a bit long, but I think I am safe cutting it to fit the shorter distance.
The second picture, am I right to assume this is where it goes. stock it went straight into the stock box on the side.
The hose is a bit short so I am wondering if I can get away with adding a spacer of some sort to prevent having to replace the hose.
its a real tight fit in there and I would have to unbolt everything to do this
this is what I am working towards unless someone can show me something else I might be missing
BTW, where will the oil mess that ended up on the bottom of my stock intake box go?
Overheating! Help ASAP KIMS CRUZER General PT Cruiser Discussions 44 18 Jul 2014 09:27 am
NEED HELP ASAP!!!! myyellowty General PT Cruiser Discussions 5 21 Dec 2008 08:21 am
NEED HELP ASAP gopackers General Turbo Discussions 5 20 May 2008 12:04 pm
Need help asap... sflamedic Tech & Performance Forum 5 13 Oct 2007 09:25 pm
PLease help asap turbomangt General PT Cruiser Discussions 5 12 Oct 2003 12:00 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
