Air conditioning only works on high setting
Old 05 Jan 2012, 11:04 pm
Default Air conditioning only works on high setting
Air conditioning only works on high setting.
I replaced the blower motor resistor today but same thing. Even when I fully unplugged it, it did the same thing. What could it be? I'm thinking wires or something. Thanks
Old 08 Jan 2012, 11:42 am
Default Re: Air conditioning only works on high setting
Anyone???
Old 08 Jan 2012, 12:40 pm
I don't know what's wrong but I can show you how it works.
Old 08 Jan 2012, 08:01 pm
I had the same problem on my old Dodge Dakota. Replaced the resistor, which didn't work. Ended up replacing the control unit in the dash. That one had a slider type control instead of a dial like on the PT. I don't know if this helps, but there it is.
2002 Limited Edition, 5 speed
Old 08 Jan 2012, 10:36 pm
Ok, so just the main control unit? I'll see if I can find it online.
Old 08 Jan 2012, 11:55 pm
That's what fixed my truck. I can't be sure what 's wrong with your car, but it had the same symptom. In my case, the blower only worked on high, but it wasn't just air conditioning. It was that way with heat too. Everything I read said that it should have been the resistor, but it wasn't.
Old 08 Jan 2012, 11:58 pm
I bought the new contol unit from the Dodge dealer. It wasn't cheap, maybe a couple hundred bucks? It's been a while, so I don't remember exactly.
Old 22 Jul 2012, 05:07 pm
Mine just started acting up, same thinmg, only working on high setting.
How hard is to replace?
Where to get the part?
Anyone have any photo's or instructions handy?
Many thanks!
Old 22 Jul 2012, 05:25 pm
Talking Re: Air conditioning only works on high setting
The dash center section isn't the same for all years, so before anyone can tell you how to remove it, we need to know the model year of the PT.
Old 22 Jul 2012, 06:29 pm
Ray_Dockrey's Avatar
Many thanks!
Like said above we need to know what year you have. But before you start tearing the dash apart I would replace the blower motor resistor or at least check it.
2003 Non Turbo Cooling Fan works on high speed only Johnnyvolvo Tech & Performance Forum 6 13 Apr 2010 02:45 pm
Setting The Inside she_so Interior Accessories Forum 4 22 Mar 2009 05:19 pm
What is the best comfort setting? Ctown Wheels, Tires, Suspension 2 18 Oct 2004 12:41 pm
Setting new standards turbomangt The Detail Shop 0 03 Jul 2004 08:34 am
