starter?
Old 06 Jan 2012, 05:12 pm
Default starter?
My PT cruiser won't start today...just get a series of clicks and no turn-over. Recently, I got an engine light and when did the OBD the codes said two things were wrong - "air/fuel mixture inappropriate" and "battery disconnected in last 50 starts".... battery checked fine, started several times after engine light came on, but won't start today...long series of clicks.
Old 06 Jan 2012, 05:28 pm
davea300's Avatar
Default Re: starter?
Do the lights and other electrics work? On first glance sounds like flat batt to me.
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 06 Jan 2012, 06:06 pm
mityqwik's Avatar
Thumbs up Re: starter?
x2 what he said or your battery term.are corroded also look at your battery cables are they in good shape and the battery ground check check to make sure it is making good contact,
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 06 Jan 2012, 06:15 pm
x3 ditto
Old 07 Jan 2012, 05:26 am
x4...bad battery and/or cables and connections.
Old 07 Jan 2012, 02:15 pm
UptownSport's Avatar
Battery disconnected is also a shared code with 'Beginning of sequence'
They just don't tell you that.
remote starter 4SPEED General Turbo Discussions 7 27 Dec 2011 10:10 am
Bad starter?? jdmickies Tech & Performance Forum 8 06 Sep 2010 11:01 pm
Starter Modifications chasetag87 Tech & Performance Forum 10 26 Feb 2010 04:54 pm
How do I get to the starter? 2003 PT 2.4L phonon Tech & Performance Forum 3 20 Dec 2009 09:04 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
