Oil Pressure sending unit
Old 13 Jan 2012, 11:56 am
Default Oil Pressure sending unit
I have a 2002 PT cruiser that, when I come to a stop and the engine idles the oil light comes on. With a slight rev it goes out, it just started this. Word has it that if I replace the oil sending unit that this may go away. On the unit I purchased it requires a torque for the unit. Does anyone know what that would be?
Old 13 Jan 2012, 04:13 pm
Default Re: Oil Pressure sending unit
Neither Chilton nor Haynes says anything about the torque specs on the oil sending unit. If you've replaced things before on the engine, use common sense and tighten it down without overdoing it.
Old 13 Jan 2012, 04:43 pm
Much easier to replace from a lift.
Old 14 Jan 2012, 12:08 am
compdr59's Avatar
A set of ramps would work if you have a standard height vehicle.
Original Owner 135k
Oil Pressure Sending Unit DEEGO Tech & Performance Forum 20 22 Feb 2016 06:24 pm
Oil Pressure Sending Unit Wire AaronP General Turbo Discussions 25 11 Jan 2015 07:36 pm
oil pressure sending unit mowerman Tech & Performance Forum 11 29 Oct 2009 12:10 am
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Oil Sending Unit rockycruiser General Turbo Discussions 9 15 Oct 2003 11:30 am
