Auto rear transmission inspection hatch leak
Old 13 Jan 2012, 08:26 pm
Default Auto rear transmission inspection hatch leak
Took the cruiser in for an oil change... shop guys said there was a hatch over the tranny pan that had some dribbles... they mentioned seeing excess RTV... is there a gasket or something that should be in there ? anyone know if that area is under pressure or is it safe for them to pull and troubleshoot ?
thanks
Old 14 Jan 2012, 01:38 pm
UptownSport's Avatar
Default Re: Auto rear transmission inspection hatch leak
I have zero idea about auto's, since no one else is answer I'll tell you what I *Think* it is.
Sounds like the differential cover is leaking. There's really no reason to ever remove this cover, parts inside don't need any servicing.
I don't believe, again, that it takes a gasket, factory specifies RTV. There's none listed at RockAuto.com.
The Factory Parts manual doesn't list a gasket, either.
Go to the tech & performance forum, there's a thread 'stickied' at very top, download your year Factory Parts Manual (They're all about the same for this part, so exact year macht nichts) and see if you can identify the part.
You can also contact threads Author, Chromenut for a Factory Service manual, it will tell you exactly what to do when removing this part, and what to use for sealer. You can also google: 'PT Cruiser Factory Service manual Download' and get it yourself directly. Again, doesn't much matter if it's an '01 or a '10 for that part.
If it were mine, I'd:
a. Wonder why the part had been removed.
b. Remove the part, clean & dry, and replace cover with silicone as a sealer.
Inspect cover for straightness during procedure.
Old 18 Jan 2012, 08:10 pm
thank you very much for your help.
Transmission leak Encara2 Tech & Performance Forum 6 01 Feb 2013 07:15 pm
Transmission leak above oil pan calcuaz General PT Cruiser Discussions 4 21 Dec 2010 09:21 am
Left-rear end smashed and a state inspection coming up :( hushpuppy The Detail Shop 3 30 Jul 2010 07:31 am
Transmission leak!!! Milowe General PT Cruiser Discussions 1 17 Jun 2008 03:44 pm
Transmission leak macster Turbo Performance 17 25 Jan 2004 05:38 pm
