Recommended Mobil 1 New Life for PT?
Old 14 Jan 2012, 05:03 pm
Default Recommended Mobil 1 New Life for PT?
Hi all,
I normally use a Fully Synthetic 5w-30 in my 2004 PT (Non Turbo).
A mechanic has suggested that for the cold weather I may benefit from 0w oil.
I was in Costco earlier and they had Mobil 1 New Life 0W-40 on offer... Chrysler's aren't listed as a suitable engine, but wondering if anyone had an opinion as to whether it would be suitable / beneficial?
Thanks,
Steve
Old 14 Jan 2012, 06:27 pm
wheelgarage's Avatar
Default Re: Recommended Mobil 1 New Life for PT?
How cold does it get, are you in the Arctic?
Regardless, Mobil One 5/30 is perfect @ 0 degrees F or above. The engine was designed to use that weight. Using a lighter weight oil might actually damage your engine.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 15 Jan 2012, 08:40 am
VNT's Avatar
VNT VNT is offline
0w-40 is fine if you can get a deal on it.
It probably has a lower pour point vs the 5w rating and will be heavier grade at 100C
You would need to look at the data sheet for the viscosity at 40 and 100 C , pour points and CCS (Cold crank simulator) specs.
In general a 0w-xx is alays better than 5w-xx as far as fluidity at low temperatures, it has to be to meet the 0w spec.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 15 Jan 2012, 11:26 am
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
Isn't the reason that we use synthetic oil in the first place is coating that stays on the parts after shut off or not running the motor for a while? So unless it is 50 below zero and at that temp you shouldn't be out anyway Why would you need 0-XX ?
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Old 15 Jan 2012, 12:35 pm
VNT's Avatar
VNT VNT is offline
Read
SAE J300
0 weight oils? - Bob Is The Oil Guy
Notice the 0W has lower viscosity at -35C, which means it will have better pumpability at low temps vs a 5w-xx or 10W-xx viscosity,
VNT
Mobil 1 0-30 MINIHEMI46 General PT Cruiser Discussions 10 08 Sep 2008 10:36 am
Mobil 1 Jimbo Tech & Performance Forum 10 22 Sep 2004 12:44 pm
Mobil one? ptgt2point4 General Turbo Discussions 12 22 May 2004 02:35 am
Mobil 1 Mr.Blonde General Turbo Discussions 33 29 Dec 2003 01:30 am
MOBIL 1 rcruisergt General Turbo Discussions 4 04 Jun 2003 06:10 pm
