I mentioned this before but never actually asked this question.
My 2001LE is awful when it comes to keeping the front and side screens demisted now its cold outside. Either we switch the blower to the front screen and the door windows mist up or we change the blower output to the side windows and the front screen mists up. This is with the air con turned on. Question is, do I have a problem with the system or is this normal? Should there be a position on the switch that allows air to blow on to the front screen AND the side screens at the same time? I hope this makes sense. ![]() |
...and to add an answer to one of your questions; The demist setting throws air on the from windshield and the two vents on the top of the dash that are pointing towards the two side windows. I had to use it this morning and it worked really well. Cleared the side windows in about 1 minute on high.
Tried fresh air and recirculation, it seems I have a problem. If I put it on windscreen/windshield I get nothing out of side vents.Only get out of side vents when set to upper body level. Hmmmm
Thanks guys |
Jassy,
The round vents at the left and right sides of the dash are not defrost vents. They will only blow air in the upper body or upper-floor outlet mix locations. They do clear the side windows nicely when aimed at the windows with the control knob turned completely counter-clockwise. Crewzin was talking about the fixed, small (somewhat oval) vents in the dash cover near the speaker grilles. Like the center defrost below the window, these should blow air when the direction control is set fully clockwise (defrost or in defrost-floor mix) and the fan is on. if they do not, then they are blocked or the air tubes are disconnected. |
Thanks sanatanadharma and others. I spoke with another owner today and she has exactly the same problem. Demists from screen when switch is fully anticlockwise and side screens when fully clockwise.
I will check for blockages in the side vents as mentioned above but I would think it unlikely that both are blocked. Appreciate the advice though guys, keep up the good work. This is the only car forum I have been on that is really active and helps all owners. My other car for work is a Kia and my daughter has a Fiat, both forums joined and get very little help or advise. |
Thread Tools | |
Display Modes | |
HELP!!! FOGGING UP MY CAR!!! | GA81PEACH19 | General Turbo Discussions | 5 | 06 Dec 2011 06:13 pm |
Windows Fogging not clearing... | afaszholz | General PT Cruiser Discussions | 3 | 09 Oct 2011 09:56 pm |
Hot Fluid Leaked On Foot Drivers Side. Car Fogging Up. Coolant Bubbling in Reserve. | 06turbolite | Tech & Performance Forum | 3 | 04 Apr 2011 07:54 pm |
NEW Screen added!! | StoneWhitePT2 | Sound and Security Forum | 7 | 09 Jun 2008 08:27 pm |
bug screen | GTcamster | General Turbo Discussions | 0 | 13 May 2003 06:10 am |
