car wont fire
Old 20 Jan 2012, 05:09 pm
Default car wont fire
i have a 04 pt cruiser with 119k on it...i had the timing belt and water pump replaced last summer...anyways today the car wouldnt fire at all...at first i was thinking i needed a new battery because it was cranking pretty weak...so i replaced the battery and it cranked good but wouldnt turn over....i looked everything over and i noticed the plastic belt guards were broken...could the belt jumped a tooth and got out of time?
Old 20 Jan 2012, 05:39 pm
UptownSport's Avatar
Default Re: car wont fire
Yes sir, that possible. If it hadn't been replaced it's likely.
If it's a not turbo, you can remove the upper timing cover with some difficulty on the '01. (Nothing technical, just have to 'wiggle' it around.)
These covers are frequently busted when tech's replace belt, so breakage could be from that, also.
Old 20 Jan 2012, 05:48 pm
the belt was replaced last summer...along with the tensioner
Old 20 Jan 2012, 06:47 pm
Sorry-
So crank; no start. First, do the keydance*, be prepared to write down "P" codes that appear in odometer.
(* Key dance, on, off, on ,off, on)
Old 08 Apr 2012, 08:42 pm
Did key dance,P03040,crankshaft positon sensor,thanks.
My Ball is on Fire! TallahasseeGT Exterior & Interior Styling 7 21 Oct 2011 11:00 am
turns over, but no fire carolinagirl Tech & Performance Forum 6 04 Aug 2011 07:54 pm
2001 will not fire, HELP!!!!!!! BigRig Tech & Performance Forum 8 08 Jan 2009 02:41 pm
My PT wont Fire mcguiresteve Tech & Performance Forum 1 16 Sep 2007 02:55 pm
My GT is on fire!!! Gary04GT Exterior & Interior Styling 12 18 Oct 2003 01:43 am
