Heater
Old 25 Jan 2012, 07:22 pm
Default Heater
I think the heater core is going out in my 03. How hard is this to replace myself.
All help greatly appreciated. aodoggie
Old 25 Jan 2012, 08:01 pm
compdr59's Avatar
Default Re: Heater
Ask XtrmDC2. I'm sure he'll share the experience....
Original Owner 135k
Old 25 Jan 2012, 08:37 pm
Default Re: Heater
Why do you think that by the way? Whats going on? Had friend tear half his dash out because he smelled antifreeze. Turn out to be a small leak under the hood.
Old 25 Jan 2012, 09:03 pm
Default Re: Heater
I'm here....Is a major PITA to do it...To me is a lot easier to do a timing belt than a heater core...
Get yourself a Haines manual and it will help you a lot, but like busted_pt said, make sure you really need a heater core...and if you have to take everything apart you may want to change the evaporator while you are there ( $80 ) just to make sure you don't have to do the whole job again, if that thing leaks later on
Old 25 Jan 2012, 10:23 pm
Default Re: Heater
Copy that... I found some moisture on the floor and there is a film on the windows, plus it has a real strong smell of anti freeze in the cab.
Guess I make an appointment with my mechanic....thank you
Old 25 Jan 2012, 11:02 pm
Default Re: Heater
Yeah, that sounds and smells like it
BTW, to get to the heater core, you'll need to remove the steering wheel, steering column, center console, radio, ac/heater controls, air bags, dash cover ,pillars, globe box, wire harness, evacuate freon,... disconnect ac evaporator,disconnect heater core hoses, remove dash frame....then you can reach the heater box and after you take it apart you'll reach the heater core....
Pretty much, a piece of cake...
Old 26 Jan 2012, 06:40 pm
Default Re: Heater
No doubt! Let us know what the damage to the wallet is. Might be helpful to someone.
Old 27 Jan 2012, 06:06 pm
Default Re: Heater
The dash tear out was what stopped me from doing it myself... dealer wanted about $1100 but a local mechanic whom I have used in the past and trust completely only wanted about $800.... we will see. Thanks everyone for all the good input, I really love this little car and with 70000 on the clock it's the first problem I've had.....
Heater Problem mechanicswife Tech & Performance Forum 5 27 Jan 2011 10:24 pm
Heater air duct cleanergmm Tech & Performance Forum 2 23 Jan 2011 07:33 pm
heater controls 4b316 Tech & Performance Forum 1 11 Jul 2009 07:25 am
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
Heater problem dwallace PT Cruiser Convertible Forum 16 15 Jan 2008 08:23 am
