GREEN CHECK ENGINE LIGHT ON HELP
Old 25 Jan 2012, 10:50 pm
PTCHANDLER's Avatar
Default GREEN CHECK ENGINE LIGHT ON HELP
I just don't even know what it is and I can't find it online
Old 25 Jan 2012, 11:14 pm
Default Re: GREEN CHECK ENGINE LIGHT ON HELP
Never heard of it either but did you do the key trick to see if there's any faults stored in the computer? Are you having any problems and are you sure it's the picture of the engine and it's green?
Old 26 Jan 2012, 09:00 am
wow thats weird, my friend said he saw a blue light for his check engin light on his 2006 pt but when i went over to look at it with obd2 it was yellow, i think he is color blind
Old 10 Feb 2012, 02:25 pm
reevescajr's Avatar
I've never tried the key trick. I got a diagnostic meter, which is very easy to use, and can reset the codes (which will of course come back if you don't fix the problem). I've gotten the check engine light a fair amount on my '03 turbo, but all but one of them have been the one that is usually caused by the fuel filler cap not being put back on tight enough (twist it until it clicks several times). I just bought a new cap, hoping it would stop this.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Check Engine Light is on-again lshykns Tech & Performance Forum 6 10 May 2011 08:21 am
