Error Code 0401
Old 27 Jan 2012, 09:04 am
Default Error Code 0401
I know that the code means there is insufficient flow in the EGR. Is the best fix just to replace the EGR valve? It's an 01 PT Cruiser.
Old 27 Jan 2012, 09:35 am
Default Re: Error Code 0401
Most of the stuff I'm reading does say to replace the EGR.
Error code p0401 on 2001 - FixYa
Old 27 Jan 2012, 09:40 am
Awesome, already got the part on the way the store for pickup this afternoon. Thanks for the confirmation.
Old 27 Jan 2012, 09:45 am
Your welcome, good luck with the fix.
Old 03 Apr 2012, 08:41 am
Got the code on my cruiser, and bought an egr valve from Napa. These instructions are good, except I have a dumb question. How do you unlock the electrical plug? It looks like the red tab is supposed to slide out. It is in a hard location to reach and worse with two hands trying to pinch one side and pull on the other.
Old 03 Apr 2012, 08:50 am
I've haven't replaced it myself, but are we talking about the same EGR valve? I don't see any electrical connection.
Old 03 Apr 2012, 09:12 am
The kit from Napa comes with the valve and a solenoid.
Here is a site with pictures, the third shows the electrical connection
BWD EGR1575 - EGR Valve | O'Reilly Auto Parts
Those pictures had to be taken with the engine out of the car, I don't have anything link that much room around the valve.
Old 03 Apr 2012, 09:57 am
As I said, haven't had to change mine. The picture comes from the Haynes manual and YES, it's a good chance they probably pulled the engine in order t get some of the pictures in the book.
The book does mention a "transducer solenoid". It tells how to take that electrical connection apart. Quote:"to unlock the EGR transducer solenoid electrical connection, push the red tab away from the solenoid and pull off the connector".
Old 03 Apr 2012, 10:15 am
I have tried that, and I have put a screwdriver in between the red tab and the gray plug and pried away from the soledoid, but the red tab does not move.
I was wondering if there is a tab to lift or ends to squeeze together where the red tab protudes on the side toward the solenoid that releases it and allows it to slide. That side is well hidden, being between the egr valve and the tube going up to the intake manifold. I don't want to break the plug.
Old 03 Apr 2012, 10:29 am
Here's a picture I just took from the Chilton manual.
Can't get error code hidinginparadise Tech & Performance Forum 5 22 Jan 2012 04:45 pm
S1 error code??? mtnbktrek Stage Turbo Kits 2 24 Feb 2009 01:42 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
0401 code erikb41 General PT Cruiser Discussions 5 20 Dec 2007 11:19 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
