Change Of Plugs and Wires Problem
Old 27 Jan 2012, 11:50 am
Default Change Of Plugs and Wires Problem
Mt 2005 Limited PT was idleing rough so I replaced the plugs and wires. (they were wasted) While doing so I noticed that the 2nd plug from the passenger side was very loose. So I did the replacement and since have noticed that while at idle about every 20 seconds the idle drops, then back to about 7000 rpms. It ran better before the change. Could it be the plugs? Wires? Don't understand, I thought that it would get better. Any ideas? Thanks
Old 27 Jan 2012, 12:27 pm
Default Re: Change Of Plugs and Wires Problem
Did you gap them at .040 ?
Old 27 Jan 2012, 01:32 pm
i would check to see if you have a vacuum leak somewhere.
Old 27 Jan 2012, 01:44 pm
Yes, gaped properly
Old 27 Jan 2012, 01:45 pm
Wouldn't this have happened before the change? How do I do a vacuum check?
Old 27 Jan 2012, 04:11 pm
UptownSport's Avatar
No- Likely something got disconnected during upper intake manifold removal, when you were changing plugs.
We're, of course, supposed to change those rubber gaskets, none of us do.
I'd strongly suggest doing as Soyo says; listen in engine compartment for a 'hissing' sound, and try to determine where it's from.
We've all seen wild plug gaps, the ignition is powerful enough to fire under a wide range of conditions/gaps.
I'd had keeping plug ceramic absolutely clean drilled into my head from early age- Free of skin oils, so I never touch them and wipe dry with a dispersant if there's any question- Same for boot internals.
Old 29 Jan 2012, 07:54 pm
Dino's Avatar
The wires are all on tight? I would check that plug that's in the loose spot to make sure it didn't get loose also.
Old 29 Jan 2012, 08:51 pm
Make sure you didn't crack a plug in the change. Pros have done it. Just a thought.
Old 30 Jan 2012, 12:31 am
fabreezai's Avatar
I agree with uptown. Possibly some kind of leak in the intake/vac situation. A old school trick, if it's not a distinctive "hissing sound" that you can locate, is to take a can of carb cleaner and "mist" not spray any areas that there could be a leak. You will hear a difference in the running of the engine (hesitation/hiccup) and be able pinpoint it. Just my 2 cents. Let us know!
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 10 Feb 2012, 02:11 pm
reevescajr's Avatar
You have to remove the intake manifold to change the plugs in an '05? I just changed the plugs and wires in my '03 turbo. They're right there in plain view. No problems, other than the oil in the #1 port, covered in another thread. But I did just what the service manual said: disconnected the battery first, and removed the wire from the distributor/coil, then from the plug. A set of plug wire removal pliers helps a lot with this.
But I agree with the other posters; chances are you pulled something loose in the process.
How should I be charged to change plugs and wires? wayneman PT Cruiser Convertible Forum 15 24 Oct 2012 12:50 pm
New Plugs & Wires ? BB General Turbo Discussions 5 09 Jan 2007 12:37 am
new plugs and wires look tough to change??? barberpole16 Tech & Performance Forum 6 09 Apr 2006 07:42 pm
Plugs/wires in turbomangt Turbo Performance 1 15 Oct 2004 09:49 am
Should I change my spark plugs/wires? crazie.eddie Tech & Performance Forum 8 18 Sep 2004 09:30 pm
