Transmission fluid leak!
Old 28 Jan 2012, 03:57 pm
Default Transmission fluid leak!
Have had transmission serviced, old threaded holes were stripped by inexperienced transmission shop. They went out of business...Had new holes put it with coils and is secure...There is a leak at the front of the transmission coming from an area with a silver-like box at the front of the tranny. I have cleaned it off and run it again to check the origin of the leak and can only determine the leak is in this area...any ideas, before I turn it over to a dealer like shop that will charge me prohibitive amounts of money to do so...
[email]radio4mike@bellsouth.net.......Mike
Old 28 Jan 2012, 07:12 pm
Default Re: Transmission fluid leak!
It's called the Solenoid Pack and you have to take off the air filter, battery and battery tray to get to it. Many owners have had the same leak.
How difficult is it to change a transmission shift solenoid - JustAnswer
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Transmission fluid leak tryanmax Tech & Performance Forum 19 22 Jul 2012 02:16 pm
Transmission fluid leak!!! ptguy69 Tech & Performance Forum 0 20 Sep 2011 11:02 pm
Winter Transmission Fluid Leak CoMo General PT Cruiser Discussions 15 11 Jan 2011 12:58 pm
autobox fluid leak mopar345 Tech & Performance Forum 4 18 Jun 2010 07:54 pm
