car jumped out of time
Old 29 Jan 2012, 10:14 am
Default car jumped out of time
last week i posted about my car not firing..anyways the garage i took it to says it appears that it jumped out of time, and told me it would cost around $300.00 to get it back in time, providing that there isnt anything else wrong with it,seems kind of odd since i had a new timing belt and tensioner put on it last summer..
Old 29 Jan 2012, 12:03 pm
Default Re: car jumped out of time
If that IS your problem, 300 isn't bad for all the work they have to do but I'd ask for some sort of guarantee that once they do all that work your PT will be up and running. Not like some of the dealers that say "this" is your problem, they do the work and you still have the same problem you went in with.
Old 29 Jan 2012, 01:01 pm
UptownSport's Avatar
Crewzin is right on that $300 isn't bad, I'd guess they're not replacing the
water pump, tensioner, and idlers for that, and they have no idea how long
and frustrating the job is on this vehicle.
IF they do do all this for $300, I'd bring them all a rack of top-shelf beer, and give them all a smack on top of it!
Old 29 Jan 2012, 01:21 pm
the manager told me they charge 4hrs labor for a timing belt...i thought that was low as well....
Old 29 Jan 2012, 01:52 pm
chigger_ns's Avatar
Sounds like a deal to me!!
Most charge $1000 and up for the belt change.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 29 Jan 2012, 03:30 pm
It was my understanding that the flat rate for that on a PT was 8hr. So if they stick to the estimate, its real cheep.
A new belt will stretch a little as it seats. If It's not self adj. you have to compensate for that. Or idler bolt not tight enough. Let us know what find.
rad fan not coming on unless jumped to battery lovemycruiser Tech & Performance Forum 1 13 Jul 2011 09:04 am
04 PT CRUISER WON'T START EVEN WHEN JUMPED lakewoodgirl Tech & Performance Forum 9 14 Nov 2010 11:11 pm
pretty sure i jumped timing... kingofyo1 Tech & Performance Forum 5 23 Aug 2010 05:22 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
New best time nuke72 General Turbo Discussions 3 10 Nov 2007 09:24 am
