Code U110C...No Fuel Level Bus Message...help please?
Old 29 Jan 2012, 06:08 pm
Question Code U110C...No Fuel Level Bus Message...help please?
I am getting this code and although I have found what it means, I have no idea how to go about fixing this problem oe even what it is related to!
I had to replace my ignition actuator switch last year and ever since my radio will not work unless I keep pressure on the key in the switch...as it "pops" back out of the actual ignition switch....being that case my friend was going to try to bypass the power, so that the power came from my cigar lighter instead....it wont work...but since having put that all back together when I started my car again this code popped up! Could that have anything to do with the code coming on or would it just be coincidental timing?
Thank you for all your comments that could help!
2004 PT Cruiser (stock radio)
Old 29 Jan 2012, 06:10 pm
Default Re: Code U110C...No Fuel Level Bus Message...help please?
could use a little more info like what year is it.
Old 29 Jan 2012, 06:12 pm
Sorry...it is a 2004 PT Cruiser...stock radio (cd player)
Old 29 Jan 2012, 06:42 pm
are you sure on that code the closest one to it is. U1100 SCP (J1850) Invalid or Missing Data for Primary Id. a U code is a undefined network commuication code
as for the key popping out it sounds like a bad lock cyl.
Old 29 Jan 2012, 08:11 pm
Were these connections done with power on? Were wires cut in this process? I would back trace all my work to eliminate these & most likely you will find your answer. Far as the radio and the key. I would look at the original repair again. After retracing this latest attempt.
Old 29 Jan 2012, 09:35 pm
Question Re: Code U110C...No Fuel Level Bus Message...help please?
Yes this is the exact code that showed ....
2004 PT Cruiser
Old 29 Jan 2012, 09:40 pm
We didn't cut any wires, only thing we disconnected was the radio itself. He was only bridging the wired not splicing them
2004 PT Cruiser
fuel level sending unit dbcruiser General PT Cruiser Discussions 2 13 Aug 2010 12:17 pm
Error Code Fuel Level Sender arizonasportsnstuff Tech & Performance Forum 2 26 Feb 2008 07:10 am
P0452 Fuel Tank Pressure Sensor Error Code dornstar Tech & Performance Forum 0 22 Aug 2007 12:08 am
A message from perrin.com Punch General Turbo Discussions 11 20 Nov 2003 10:30 am
