TC & ABS lights on/new front tires
Old 04 Feb 2012, 03:21 pm
cannesman's Avatar
Default TC & ABS lights on/new front tires
Howdy. Just replaced both front tires on the wife's 03 gt. Now having issues with the TC and ABS idiot lights lighting up. Tires replaced were same size as the ones that came off. Any insight as to why the idiot lights?
It's the wife's PT......but I get to drive it on occasion
2003 Inferno Red GT.........no mods.....stock.
Old 04 Feb 2012, 04:19 pm
Default Re: TC & ABS lights on/new front tires
Might have knocked some rust loose & interfering with abs sensor. or damaged sensor or wire. Check these out & reset codes.
Old 06 Feb 2012, 10:36 am
There's also a toothed wheel that the sensors monitor that may have been damaged by the wheel replacement.
I believe a good code reader can pinpoint which wheel is causing the problem - short of that, take off one wheel at a time and inspect everything.
Old 06 Feb 2012, 08:29 pm
2xs , metal rust will be attracted to the toothed ring. Compressed air will help there.
Old 07 Feb 2012, 07:56 pm
cannesman's Avatar
Thanks guys, sounds like a trip back to the tire store. I'm a bit tortured here, when the store replaced the tires they gave me the wrong size, which was discovered by the a-for mentioned warning lights. I called them and told them and they said they had put 205's on and the tires on there were 215's. This was what set the lights off, according to them. So, back to the store, replaced the fronts with 215's, still have the warning lights on. I'll pass along the info you've given me if necessary. Thanks again.
Old 12 Feb 2012, 02:18 pm
cannesman's Avatar
Follow up..............before I could get the car into the shop, we had a snowstorm. Wife was driving to work and lost some traction in the snow, both abs and traction control idiot lights went off and traction control is back to where it should be. Wanted to post this in case anyone else has this problem when front tires/wheels are replaced. Thanks again.
Rear and Front Fog Lights not working-Help! backtorealityuk Tech & Performance Forum 1 20 Dec 2010 03:50 pm
Front tires, how many miles do they last? ProDigit Wheels, Tires, Suspension 10 13 Dec 2010 09:25 pm
Replacing front tires - stick with H rating? coolvirus Wheels, Tires, Suspension 10 17 Feb 2005 05:54 pm
Front tires wearing out sooner stirfry Wheels, Tires, Suspension 5 11 Jun 2004 03:55 pm
lights in lower front cowl gonzomania Exterior Accessories Forum 8 16 Dec 2003 11:47 pm
