whistling sound
Old 04 Feb 2012, 08:37 pm
Default whistling sound
Ok, so I just acquired a 2002 Cruiser Dream and this evening I am hearing what sounds like a whistling sound coming from passenger side engine bay.
Does the timing belt make any type of noise when going bad?
Serpentine belt there as well I believe? If so should, I spray it and see if the squeaking goes away?
Anything else it could be?
The car has 60000 miles
Thanks
Nick
Old 04 Feb 2012, 08:42 pm
mdfrodolives's Avatar
Default Re: whistling sound
Don't spray anything on your belts. It will screw them up.
As far as the whistling goes, I have no idea--other than a needed belt adjustment.
Tim
Old 04 Feb 2012, 08:55 pm
when you say belt, are you referring to serpentine or timing?
Tim
Old 04 Feb 2012, 09:08 pm
JonnoSkye83's Avatar
when you rev the car in neutral / park do the revs "come down" immediately or do they come down slowly? if they come down slowly and the whistling noise changes when revving the engine, check your vacuum hose under the "modesty cover" it may be split and causing a whistle. had to replace mine a few weeks ago.
~Jonno
2000 PT Cruiser Limited Edition Auto
Old 04 Feb 2012, 09:52 pm
Thanks, but I think its more like a belt squeaking noise
Whistling noise, belt related? cannesman General PT Cruiser Discussions 13 09 Feb 2014 03:17 pm
whirring whistling noise fancy Tech & Performance Forum 1 29 Oct 2011 05:58 pm
whistling noise fancy Tech & Performance Forum 1 11 Oct 2011 06:43 am
Shes'a whistling dixie WolfmanG General PT Cruiser Discussions 3 14 Jul 2011 09:03 pm
Steering is whistling...?! whitbyPT Wheels, Tires, Suspension 2 27 Jul 2008 01:42 pm
