Automatic Transmission
Old 07 Feb 2012, 05:35 am
Default Automatic Transmission
I just received my Haynes Repair manual PT Crusier 2001-2010, copyright 2011. Under Maintenance Schedule for 30,000 miles and every 30,000 miles it says change automatic transmission fluid and filter. Isn't that an overkill?
Old 07 Feb 2012, 06:51 am
Default Re: Automatic Transmission
I think it's overkill - unless you are in stop-n-go traffic all the time.
I had mine flushed at 50,000 and again at 100,000 miles.
Old 07 Feb 2012, 12:22 pm
UptownSport's Avatar
I'd follow the owner's manual, unless these guys say otherwise.
Old 07 Feb 2012, 12:34 pm
cruserdad1976's Avatar
id get a pan with a drain plug and at least change the filter ever other oil change
Old 07 Feb 2012, 08:34 pm
I'm sorry but changing the trans filter every 6000 is the equivalent of changing the oil filter every 100 miles. I do like the drain plug idea. But treat it like a pistol. Don't pull it till you need to. I'd go with UptounSport on this one!
Old 07 Feb 2012, 10:15 pm
I think he meant every other transmission oil change ...
Old 07 Feb 2012, 11:24 pm
If so, my apologies. In that case put the filter in chump change compared to the cost of fluid.
Again my apologies. Thought he meant every other oil change.
Old 08 Feb 2012, 06:43 am
the trans fluidl pan w/drain plug is like $18 at Rockauto. Advance Auto sells ATF4 fluid that is on the AllPar recommended list to be equivalent to MOPAR ATF4 but less expensive
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Automatic Transmission Learning Procedure?!?! GLH_TC 16V General Turbo Discussions 11 11 Jul 2013 09:34 pm
Automatic transmission oil change bhunt41 Tech & Performance Forum 2 02 Dec 2011 11:10 am
automatic transmission (2002 pt cruiser) javolier Tech & Performance Forum 15 20 Oct 2011 07:25 am
Automatic Transmission Pan With Drain Plug Matt42 Tech & Performance Forum 3 18 Aug 2010 11:31 pm
using second gear with automatic transmission? gfx Tech & Performance Forum 2 18 Jul 2004 02:24 pm
