Alarm arming chirp
Old 09 Feb 2012, 11:53 am
Default Alarm arming chirp
I borrowed this from another site and tried it but it does not work on my 2001 LE. Anyone know if this should work?
"I have a 2002 LE PT and work the late shift. Is there a way to disable the horn feature, which sounds each time I lock and arm the sentry system? I have a neighbor that sleeps lightly. Thank you. - Angelo, from New York.
Yes, that's possible. The horn chirp that signals that the doors have been locked can be turned on or off by using the following procedure:
1. Insert the key into the ignition switch and turn the switch to the ON position.
2. Press and hold the Unlock button on the transmitter for between four and ten seconds.
3. Continue to hold the Unlock button and press the Lock button.
4. Release both buttons. A chime will sound to signify that the process is complete."
Old 09 Feb 2012, 12:00 pm
Default Re: Alarm arming chirp
Yes, It should work.
Old 11 Feb 2012, 09:12 am
JonnoSkye83's Avatar
if its a UK model, then ..no it wont work
apparently... the chirp feature was removed on the UK models
~Jonno
2000 PT Cruiser Limited Edition Auto
Old 11 Feb 2012, 09:23 am
EDIT: Yes, it should work if it's a U.S. model.
Old 11 Feb 2012, 03:01 pm
Yes, I'm in UK, so no chirp.
Thanks, saved me getting frustrated trying to find why it wont work.
I suppose no one knows if there is a way to "reinstate" this in the alarm module, is there?
Alarm chirp Jassy General PT Cruiser Discussions 3 14 Sep 2012 10:21 pm
2002 Limited edition Chirp new owner! Help vikingsraven Sound and Security Forum 10 12 Feb 2012 08:02 am
alarm, keyless entry chirp partyd Sound and Security Forum 5 09 Nov 2010 09:45 am
Red security alarm light but no alarm! TrishsPT Sound and Security Forum 9 02 Aug 2010 02:38 am
Weird chirp........... smoothedge69 Tech & Performance Forum 10 15 Apr 2010 07:52 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
