Ice on door hinge
Old 12 Feb 2012, 10:06 pm
Default Ice on door hinge
The snow and water from around the windshield wipers ran down the inside of the door and froze around the hinge. Am I missing a seal or do others have this problem?
Old 12 Feb 2012, 10:28 pm
Smile Re: Ice on door hinge
This area not weather tight.
Old 13 Feb 2012, 12:59 am
Default Re: Ice on door hinge
yup. the wife's constantly complaining about it during the winter months. my 2002 stays in the garage so i never experienced this dilemma.
Old 13 Feb 2012, 08:47 am
UptownSport's Avatar
There's a piece of insulation they added inside front fender-
This area usually fills up with leaves / debris in any car, however, with this
piece, it diverts water toward the door, you'll get water on hinge and at lower
leading edge where it normally wouldn't be.
(You can see leaves built up in this photo)
I'd:
Wash down the 'plenum' area and see if debris will flow out
If that no workee,
Remove the piece, it's not needed
Old 13 Feb 2012, 10:52 am
This is why I keep the Cali PopTop cover on my PT in the winter, keeps all the crud from happening.
Old 19 Feb 2012, 03:23 pm
One more thing that "couldn't hurt" is to simply spray the hinges and the immediate surrounding area down with WD-40 several times during the winter. If water doesn't stick to the hinges and the hinge area, then ice won't form on them.
Jerry
Old 19 Feb 2012, 04:12 pm
Jerry
I like to use silicone spray because I don't have to worry about the weatherstrip being affected by the spray itself. Some oil based lubricants can affect rubber components in a negative way. Not sure about WD-40 in particular.
Old 19 Feb 2012, 04:26 pm
WD-40 is recommended to condition rubber so I would say it's "good" for it. It keeps it soft and pliable and it will keep the hinges lubricated even during the rest of the year. It contains no oil as we know the definition of oil.
Jerry
hood hinge relocation ? bonsylrc Exterior Accessories Forum 9 13 Feb 2012 10:52 am
Gas Door Off Of A 04 Hiperguy Classifieds: For Sale/Trade 1 28 Sep 2010 12:01 am
Going out the door airevac19 General PT Cruiser Discussions 18 19 Aug 2004 08:33 am
Door Handles bigtommy83 Exterior & Interior Styling 0 25 Jun 2004 09:20 am
Flipen Hood Hinge RetroPT Exterior Accessories Forum 1 23 Dec 2002 09:34 pm
