Sporadically Needs Jump Start
Old 17 Feb 2012, 07:40 pm
Default Sporadically Needs Jump Start
I've searched and couldn't find any answers.
Here's the situation:
Cruiser will not start randomly after having started within the past hour. For example, it will take her to the grocery store but will not start on the way back. Car had similar problems last winter but she wasn't driving it regularly so we just figured it had something to do with that. She got a new Die Hard battery last winter. This has occurred twice at this point but we need to find out what is going on so she stops getting stranded.
Battery and alternator have been tested and passed.
*whoops misspelled title.
Old 17 Feb 2012, 08:10 pm
Question Re: Sporaticly Needs Jump Start
Doesn't crank or cranks but doesn't fire?
Old 17 Feb 2012, 09:10 pm
mdfrodolives's Avatar
Default Re: Sporadically Needs Jump Start
Since you mentioned you got a new Die Hard battery, I can assume that Sears put that in. I had Sears put in a Die Hard for me and their serviceman broke off one of the prongs on the bottom of my air box. He also did not put any battery protector of any kind on the clamps and posts. Therefore, within a year the corrosion was so bad on the terminals that my clamps were eaten through. I had to get a new wiring harness as a result.
When getting a new battery for a PT that has the airbox covering the posts, it's always a good idea to spray some battery protectant on the clamps and posts. Otherwise, it's amazing how fast the corrosion occurs on our PT's.
P.S. Sears also threw away my battery thermal blanket.
Tim
Old 18 Feb 2012, 10:35 am
It doesn't really crank. There is corrosion on the terminals but I don't know if it enough to cause this problem, though it would explain the good battery and such. I will start by replacing those and see where we get.
Yeah I have learned through her experiences with sear's not to take it there anymore. She had rear brakes done and now they make a loud knocking noise everytime she stops, and this started when she pulled out of the Sear's parking lot after getting the work done. THey say it's not their fault and don't know what is causing the noise.
Old 18 Feb 2012, 05:26 pm
Thumbs up Re: Sporadically Needs Jump Start
Clean those terminals. Try to save your originals. Cutting them off an using those clamp on replacements just create an extra connection to corrode.
Jump Start a problem? niel General PT Cruiser Discussions 7 29 Aug 2011 04:55 pm
'04 Cruiser won't start. failed jump attempt TrinityLayne Tech & Performance Forum 4 08 Aug 2011 06:15 pm
Not even a jump worked! Any ideas? durhamchic Tech & Performance Forum 11 16 Jun 2011 04:06 pm
All Electricity gone - Jump start fails also JPGP General PT Cruiser Discussions 5 08 Dec 2010 06:18 pm
Door lock problem after dead battery/jump start Mal Interior Accessories Forum 1 11 Jun 2009 09:32 pm
