Hello,
I own a 2006 PT Cruiser Touring Edition. I just bought it used from the car dealer in November 2011. It only had 29,000 miles on it for less than $10,000, which I thought was good. Anyways, the other day, I was on the highway and I went to turn on my cruise control like I normally do and the cruise control light didn't come on the dash when I pushed the on/off button. I tried turning the engine off and turning back on but still no cruise light. I tried that a couple of times. After searching the internet, I found a solution that worked for me. A couple of internet sites said to remove the negative (black) battery cable for a few minutes. They suggested to pump the brake pedals a few times afterwards to get all the power out. I left it unhooked for 20 min. Then I hooked up the negative (black) battery cable. When I started driving on the highway, I pushed the on/off button on the cruise control and the cruise control light showed up and I was able to use the cruise control as normal. Just wanted to pass this along if anyone else was having the same issue I was. Thanks! |
Welcome to the forum. Nice PT and sounds like a great deal.
Agree. We tell almost everybody that comes to this forum with a problem to take the negative battery cable off. It resets the computer and takes away any stored old fault codes. It's like hitting the RESTART on your computer. It clears a whole host of problems. Your car might run rough for a minute or so after starting because the computer is re-learning your settings but as long as everything is right with the engine and sensors, it will smooth out and run properly after that. Pushing on the brake pedal after the negative battery cable is off gets rid of any excess residual charge. Last edited by CREWZIN; 18 Feb 2012 at 08:06 am. |
My cruise control also does not work, and the check engine light has come on for the second time in a week (it went off by itself the first time). So, I will try this disconnect right now, before I go anywhere today, and in an hour or so, I'll see if this might not help me.
No joy in Muddville. I disconnected the battery yesterday. And, still no cruise control, the airbag light is still on, and the check engine light is also still on. I guess it's off to the mechanic next.
My 2006 PT is only the base model so it doesn't even have cruise control, but I would love to get it installed if it is possible.
![]() First-time owner of a 2006 Chrysler PT Cruiser (base model)! Loving it so far and I got it for a steal of a deal! ![]() |
![]() Quote:
There is a thread around site somewhere of a user installing a kit. Maybe someone remembers who it was ![]()
![]() 2006 Touring Edition in Cool Vanilla...aka/Ghost |
Its not a real difficult install if the wiring is already there. I installed it on my 09 several years ago. It does require removal of the steering wheel so the airbag has to be removed.
Other then that its pretty much just plugging stuff in and installing the vacuum reservoir. The install instructions are wrong so if the existing wiring is there you don't do any splicing even though the instructions say too at the plug that goes to the steering wheel. |
Yeah when I have the money to do it I'll get one installed. And it may be an easy process but I am a bit mechanically challenged and will need someone to do it for me lol. I don't want to remove the steering wheel and totally damage things. :P
I recently installed my cruise control fortunately it was pre-wired and all I did was replace the clock spring, install the switch, servo and vac accumulator under the bumper
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473 Airaid SynthaFlow Cold Air Intake 300-198 UltraGauge EM v1.2 Bridgestone Turanza Serenity Plus 195/65r15 AKA "Banana Car" ![]() ![]() ![]() ![]() |
Thread Tools | |
Display Modes | |
2006 PT Cruiser Touring Edition | Reynolds1961 | Tech & Performance Forum | 3 | 04 Oct 2010 09:31 pm |
2006 PT Cruiser Cruise Control | LINK1951 | Tech & Performance Forum | 3 | 04 Aug 2010 07:05 pm |
2006 PT Cruiser Touring Edition | zharrison07 | General PT Cruiser Discussions | 15 | 16 Feb 2010 10:16 am |
2006 PT Cruiser Touring Edition - only 15500 miles! (san jose south) $11999 | skylight | craigslist | 0 | 16 Jul 2007 07:30 pm |
2006 Chrysler PT Cruiser Touring Edition 4-Door (pacifica) $12800 | skylight | craigslist | 0 | 11 Jul 2007 04:00 pm |
