PT Hellllp!!!!
Old 18 Feb 2012, 11:22 am
Default PT Hellllp!!!!
I was driving home last night, and I noticed the temp sensor was fluctuating from the halfway mark, where it has always stayed since new, and the 3/4 mark. When home, I opened the hood, and there is coolant all over the place, mostly near the battery area. Any ideas? The hose does not appear to be leaking.
Old 18 Feb 2012, 11:45 am
Default Re: PT Hellllp!!!!
You might have a pin-hole near the top of the radiator or the top hose. If you can get it to a shop that has a pressure tester, that will show you where the coolant is coming from. They just screw it on whee the radiator cap is and add pressure. Any pin-hole or leak will show itself.
Old 18 Feb 2012, 11:52 am
compdr59's Avatar
Check your radiator. It's common that they leak where the plastic meets aluminum. Get it fixed immediately before it overheats and causes more problems.
Original Owner 135k
Old 18 Feb 2012, 05:31 pm
Exclamation Re: PT Hellllp!!!!
Top off your fluid before you go anywhere!!!
