Check engine light
Old 19 Feb 2012, 09:30 pm
Default Check engine light
Hi I have a question about the check engine light. I have a 2009 PT Cruiser non turbo and the check engine came on today. I've had this problem 2 months ago the light came on and not long after that it started jolting backing i don't know what you would call it, took it to auto zone and the cam sensor needed to be replaced so i replaced it and everything was fine. Hadn't had a problem til today the light came on and my dad and i took it to auto zone to get a code and there was no code. I drove it all day today and it was fine it drove like normal. My question is if there is no code and it drove fine then what could it be?
Last edited by yadayada0007; 19 Feb 2012 at 09:31 pm. Reason: I should say that it has 58,000 miles and has had an oil change last month.
Old 19 Feb 2012, 09:57 pm
Default Re: Check engine light
If there was no code (and you can get the code yourself without Autozone) then you might have had a temporary fault that didn't produce the fault code.
By the way. I wouldn't be surprised if your camshaft sensor fails in a short while. After market sensors don't last very long if they work at all. All your sensor should be replaced by a MOPAR/Chrysler part. Other after market sensor are made with inferior parts.
Next time the engine light comes on, follow these instruction on how to pull the code yourself.
How to retrieve fault codes.
Old 19 Feb 2012, 10:03 pm
Since the cam sensor went out once i read that it could be the timing belt but when i called a mechanic he said its unusual because my mileage is so low. My manual said to replace it at 96,000 i m at 58,000. I just worry if its anything super serious because i do not have the money to cover it
Old 20 Feb 2012, 09:05 am
VNT's Avatar
VNT VNT is offline
You used a autozone cam sensor.
Go buy a real one from Mopar. Seriously, I dont know how many times it has been stated here, use mopar sensors or take your chances with intermitant problems.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 22 Feb 2012, 03:38 pm
I got a code its 0456 so its either a vacuum leak or a loose or defective gas cap, a cracked hose or something all can be repalced easy i believe
Old 17 Jul 2013, 10:21 am
I have a 2009 PT Cruiser and the check engine light came on again ( this is the fifth time in approximately 4 years). the Car just went past the 100,000 miles mark and of course the extended warranty has just expired. I tried to retrieve the code and the only thing that came up was 'Done" so no code to work with. Should I just take it to my local guy or should I bring it in to a Chrysler dealer. If I do that I am certain that the cost would be in the 250 to 300 dollar range. Any Suggestions?
Ill say one thing the check engine light on any of my other cars ( not Chrysler of course have not come on like this.) Sorry to say but this is my first and last Chrysler.
Old 18 Jul 2013, 05:43 am
Send a message via AIM to verongome Send a message via Skype™ to verongome
Well if you buy the real deal you won't have to replace it again and again and you won't face much problem. Just go and get mopar.
BacklinksVault
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Check engine light is still on! cowboyinboxers Tech & Performance Forum 2 01 Jun 2010 06:44 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
