Front wheel arch liner
Old 22 Feb 2012, 10:16 am
Default Front wheel arch liner
I've purchased a new plastic wheel arch liner, after some low life vandalised my car. There are several small bolts around the outer edge - no problem here. However, where the liner attatches to the inner wing there appears to be three studs (?) with no obvious way of levering them off. reaching behind one I can feel something like a screw thread, but it might just be serations. I don't want to force these if they're not supposed to be. Has anyone replaced one of these liners and, if so, any tips?
Old 22 Feb 2012, 10:48 am
Default Re: Front wheel arch liner
They are push in (essentially single use) fasteners. The blind end is a "serrated" and catches the edges of the hole.
Most auto parts stores will have new replacements,
Easiest way to remove them is with a special tool to pry them out. Try using an old fork with a middle tang (or two) removed. You can also cut them off with side cutters or a knife behind the large disk.
Old 22 Feb 2012, 11:25 am
Thanks mate! I appreciate that.
Old 22 Feb 2012, 12:23 pm
I'm a little put off with this, the panel tool at Advance Auto I bought year before last at $5 less than what they show now ($17.99). I will tell you though, this tool has been one of the handiest tools I've had with my PT. I use it all over the place. Really works well.
Buy KD Tools Panel Clip Plier KDT3705 at Advance Auto Parts
Old 22 Feb 2012, 03:32 pm
Thanks Chromenut. I always wondered how best to remove these parts.
Andromeda I found these on this website in the UK 12.98 plus VAT.
Groan/creaking sound when turning wheel right (front right wheel) 2k2ptc Wheels, Tires, Suspension 8 02 Sep 2012 10:52 am
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
Rear Wheel vs Front Wheel OD difference moparmadness Turbo Wheels/Suspension/Handling 0 20 Sep 2011 01:23 pm
Right Front Wheel Spin johnjsa Wheels, Tires, Suspension 5 12 Dec 2009 03:08 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
