2002 PT died & will not start
Old 24 Feb 2012, 10:56 am
Red face 2002 PT died & will not start
Several days ago I did not put my gas cap on tight & the engine light came on so I checked the codes & thet was 2 codes one for the loose gas cap & the other was code 1684 - battery has been disconnected in last 50 starts ... but I have NOT disconnected the battery .... NOW she died the other night & I get CODE 340 & CODE 1684 ........... tested the wires to the camshaft sensor & the are good so I replaced it but nothing....she wont start even jumped it because my battery is getting weak, so I had to get her towed home.......Now what ????? Any ideas ??? I'm going blind from looking stuff up !!!!: ( Battery is new) the fact that I was getting Code 1684 Weeks before this has me wondering 'Could a bad alternator cause Code 340??' ..its been squeaking..
Old 24 Feb 2012, 12:15 pm
Default Re: 2002 PT died & will not start
Kim, welcome to the forum. What mileage in on your PT? If it's anywhere near 100,000, there's a good possibility that your timing belt has snapped.
Old 24 Feb 2012, 01:45 pm
Dino's Avatar
Try a new battery, mine wouldn't start with a jump when the battery was really weak. If they engine sounds like it's turning to freely than maybe your belt snapped.
Old 24 Feb 2012, 03:20 pm
UptownSport's Avatar
With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Visually inspect all the wiring and connectors in the circuit
Check for continuity in the circuit wiring
Check the operation (voltage) of the camshaft position sensor
Replace the camshaft position sensor as required
Check the crankshaft position circuit as well
Replace circuit wiring and/or connectors as required
Diagnose/replace the PCM as required
Battery disco code is ALSO 'beginning of sequence' - no idea why.
Old 24 Feb 2012, 04:27 pm
Oh please don't say timing belt....that would be soooo bad for me at this time....had one go out on a Fiat once but the engine turned much fast when you'd crank it.....I have been reading alot of your info to others, could it be a short in the alternator ?? Trying to get all the input I can so when I jack it up tomorrow I can check all options...Thanks for all your expertise !!!
Old 24 Feb 2012, 04:43 pm
As the others said, it could be a number of things including what the code was for, the Camshaft sensor. I just wanted to get the information about the mileage to eliminate the possibility of it being or not being the timing belt. You still didn't say what your mileage is.
Old 24 Feb 2012, 08:21 pm
Sorry about that..it does have aprox 130,000 hwy miles ( on the freeway off the freeway) & has been maintained very well..every time I change my plugs the old ones still look new, no oil leaks. I replaced the power steering belt once, I've flushed my radiator, replaced battery last year, change oil every 30,000 ... if not for a squeaky alternator I haven't had any problems ...... could the alternator be a possibility ???? I admit I have been using my high beams a lot , low beams just didn't seem bright enough (get's dark here on the Calif.coast) I thought that the plastic was cloudy & causing the light to be dimmer.......could that cause a code 340 ???? Thanks for taking the time to give me your input, it is appreciated !!!!
Old 24 Feb 2012, 08:23 pm
All that great maintenance you did (except changing he oil every 30,000) but you didn't say anything about the timing belt.
If the timing belt did break, the cam shafts aren't turning anymore. Not turning, the sensors see the non-rotation of the cams and crank. The 340 is the code for the cam, if I remember right 344 is the crank. Either one is a good indication that the belt is gone especially at your mileage.
Dill's Avatar
how many miles were on the pt when you got it? Mine had 92k and timing belt was replaced...
if uve had it a while I'd guess the timing belt could be the issue, possibly stacked with other problems giving you the error codes.
peek underthe plastic timing belt cover from under the hood, use a flat head to pry it open and peek in with a flash light
Old 25 Feb 2012, 10:30 am
No it did have 100,000 on it when I got it & it was very clean...the man had a long commute to work I know where he took this car to maintain it (good local shop) don't know what or if he had replaced anything. I hope its not that belt & I did have one go out in another car before this just doesn't sound the same & I don't get the battery thing (battery is only a yr old)should not be dead & why that code ??? No on has said IF a bad alternator could send out that code ???? I also forgot to mention a few days before it didn't start right away, & that has NEVER happened always starts right up I had to try a few times..Guess I'll find out today...I'll peak at the timing belt to see if there is slack in it
2002 PT wont start TampabayCruiser Tech & Performance Forum 6 10 May 2011 05:41 am
Overheated, died on interstate, won't start [[[Long post ahead]]] logandj Tech & Performance Forum 2 29 Dec 2010 07:17 pm
2002 PT CRUISER WON'T START -98k MsLeah General PT Cruiser Discussions 9 12 Jun 2010 08:19 pm
Car died, wont start! HELP PLEASE!!! Zerotolerancecustoms Tech & Performance Forum 8 15 Aug 2009 03:42 pm
2002 PT died on me...HELP miklin Tech & Performance Forum 4 05 Feb 2009 09:19 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
