Oil in Spark plug tube
Old 24 Feb 2012, 05:37 pm
Koch's Avatar
Default Oil in Spark plug tube
car is still new to me today i pulled out the spark plug wire closest to the oil cap on my 2004 PT N/A the one that can be removed without taking the upper plenum off and the whole boot of the plug wire was soaked in oil and so i got a clean rag and pushed it down the in the tube and soaked up a bunch of oil, my question is... Is this something that is a common problem that needs to be fixed? put new valve cover gasket on? or is it possible that someone spilled oil and never cleaned it up????
PO344 O' how I hate you!
-2004 Chrysler PT Cruiser Limited- Inferno Red
Old 24 Feb 2012, 06:36 pm
Default Re: Oil in Spark plug tube
Change the valve cover gasket set. Several post on how to do it right.
Old 24 Feb 2012, 11:34 pm
mdfrodolives's Avatar
Actually, as you're changing the valve cover gasket, make sure you change the spark-plug tube gaskets. Cruisers tend to leak from these seals. And your problem seems like it's just another tube-seal issue.
Tim
Old 24 Feb 2012, 11:39 pm
Koch's Avatar
Tim
its will be atleast a month before i get the time to change these gaskets and seals will it hurt to drive the car till then?
Old 25 Feb 2012, 08:08 am
Koch's Avatar
done some looking in2 this project, doesn't look like it will be that hard, i think i might make a change to plans and try to get it done next weekend
Old 25 Feb 2012, 08:39 am
This might help.
Also, according to Haynes, the valve cover bolts should be tightened down in 3 steps.
Step 1: 40 in-lbs
Step 2: 80 in-lbs
Step 3: 105 in-lbs
Old 25 Feb 2012, 09:12 am
Originally Posted by CREWZIN View Post
This might help.
Step 1: 40 in-lbs
Step 2: 80 in-lbs
Step 3: 105 in-lbs
Not ft-lbs
Old 25 Feb 2012, 09:14 am
Tim
A set will come with the tube gaskets!
Old 25 Feb 2012, 12:20 pm
Originally Posted by Busted_PT View Post
Not ft-lbs
NO, not Ft-lbs. According to the manual. I don't understand what your trying to say?
Old 25 Feb 2012, 02:43 pm
UptownSport's Avatar
seems people get confused as in lbs is rather uncommon, and he was just reinforcing the correct metric
Spark plug gap. AJ2005 General Turbo Discussions 7 15 Jun 2012 01:50 pm
need spark plug help please edj8 Tech & Performance Forum 42 25 Aug 2010 12:47 pm
Oil in the spark plug 02PurplePT Tech & Performance Forum 4 10 Jul 2010 05:05 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
Spark Plug GAP duffner General Turbo Discussions 11 16 Mar 2008 12:55 pm
