Overheating Pt Cruiser 2005 desiel
Old 25 Feb 2012, 09:46 am
Default Overheating Pt Cruiser 2005 desiel
Hi
Wondering if someone could help me, the last few weeks my cruiser is overheating, there seems to be no leaks but i am having to put alot of water in it. I noticed today that the fan is not running when i was trying to look for a leak or something.
any idea how i can check to see if its a fusee possibly or something simple as the cost to get anything fixed in the UK is stupid prices
many thanks
Dave
Old 25 Feb 2012, 09:49 am
Default Re: Overheating Pt Cruiser 2005 desiel
oh i must say even tho it is overheating, there is no heat from the heater when i put it on hot
Old 25 Feb 2012, 10:51 am
Sounds like the thermostat is bad. I guess diesels have one?
Old 25 Feb 2012, 01:03 pm
It's possible bad thermostat but lack of heat is usually from air trapped in the coolant system from being low in coolant. Air seeks the highest point which is the evaporator in the dash. No water running through it, no HOT air. Happened in my Vette and cruiser.
The fan not running is probably you overheating problem. Known problem in all the cruisers including your diesel. The leak your not seeing might be from evaporation of a small leak onto a hot part or worst case, you might have a small head gasket leak.
2005 PT Cruiser Overheating Issues! EnRAM Tech & Performance Forum 12 01 Aug 2016 04:54 pm
Yet... Another Overheating Cruiser... MobbedPT Tech & Performance Forum 7 10 Jul 2011 10:30 am
2005 pt touring overheating kudos383 General PT Cruiser Discussions 7 28 Apr 2011 04:36 pm
PT cruiser Overheating jdb3546 General PT Cruiser Discussions 2 08 Oct 2010 11:51 pm
Another OverHeating Cruiser....... FloridaCrusier29 General PT Cruiser Discussions 8 26 Jul 2007 09:25 pm
