Part Name and/or Number
Old 25 Feb 2012, 11:59 am
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
Default Part Name and/or Number
I have an 06 Turbo Lt, I need to know the name and number for the sensor that goes into the inter cooler pipe that hooks up to the throttle body. There are two connections, one is a sensor and the other is a hose, Can anyone help with this, Thanks
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Old 25 Feb 2012, 12:45 pm
Default Re: Part Name and/or Number
What happened? you broke it? ...
Old 25 Feb 2012, 01:50 pm
ROCKETMAN8060's Avatar
I think your going to be able to find it here!!!
http://www.hugginsnet.com/ptcruiser/...rtsCatalog.pdf
ROCKETMAN8060
Old 25 Feb 2012, 02:26 pm
UptownSport's Avatar
Just a slip in Mopar IAT?
If you need one, I'm sure I'd have it used.
Old 25 Feb 2012, 06:56 pm
PT_Panel's Avatar
Yep, old fumble hands, when I was taking it out of the old pipe, my hands slipped when I had it about half out of the pipe, I should have taken it out BEFORE I took the pipe off the throttle body but I didn't. I didn't break the metal sensor but it broke the plastic that holds it. Wonder if would still work? I called the parts dept in Shelby and the guy said DUHHHHHHHH. Didn't even know what I was talking about, forget them, Man I miss our dealership. Can you lose boost if that plug/sensor doesn't make a complete seal should I put some gasket sealer around the grommet, It is pretty tight just asking. Thank ya'll for the come backs. they are appreciated
Old 26 Feb 2012, 05:39 pm
You can cut and splice it into the existing harness when you get the new/used one. I had to lengthen mine when I switched over to the K&N Apollo intake.
Jerry
Old 27 Feb 2012, 11:12 am
PT_Panel's Avatar
What is the piece up next to the strut cover? it that a catch can? My wiring is ok I just messed up taking the old one out of the pipe, should do it before taking the pipe off. got one coming from e-bay. Small delay, lots of time.
Old 27 Feb 2012, 12:28 pm
Thats an anti-siphon solenoid to prevent the SNOW system from siphoning the water/meth mix while it isn't activated.
Jerry
Need Help With OEM part number csd PT Cruiser Convertible Forum 8 05 Nov 2011 10:21 pm
PCM Part Number? sandy64 General PT Cruiser Discussions 3 27 Apr 2011 11:48 pm
Need a part number! skokz Tech & Performance Forum 1 17 Sep 2008 06:57 pm
Stage II Part Number strangelove Stage Turbo Kits 6 22 Oct 2004 10:34 am
Part number for a Stage 1 Iggy Stage Turbo Kits 3 06 Oct 2003 09:26 pm
