Rear door "sail panel??" ??
Old 05 Mar 2012, 07:11 pm
Wink Rear door "sail panel??" ??
-I'm speaking about the plastic?? panel at the rear of the rear door windows.....how do I remove these? I need to replace one...I'm not speaking about the stick on chrome covers that GO ON THESE-I'm speaking about the factory installed panels themselves.....may be they are called something else??
Old 05 Mar 2012, 07:55 pm
Default Re: Rear door "sail panel??" ??
If you look at the replacement you will see mounting taps. This will point you to the locations of the screws under the window channel rubber. If I remember correctly.
Old 06 Mar 2012, 07:26 am
Wink Re: Rear door "sail panel??" ??
OK, Thanks!! So-it IS called a sail panel then?
Old 15 Mar 2012, 04:10 am
-just ordered a new one-its called a "C" pillar applique.........better be more than an applique for almost $80.00!
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
DIY Sail Panel Mod for your aftermarket tweets Kawizx9r Sound and Security Forum 25 13 Oct 2010 05:58 pm
Part number for "PT" door emblems on 2008 Dream Cruiser 5 gpr75 General PT Cruiser Discussions 6 16 Jul 2010 12:15 pm
Tire size for staggered 20" Rear 18" Front ???? dpolley Wheels, Tires, Suspension 4 10 May 2009 09:54 pm
