Traction control makes odd noise.
Old 07 Mar 2012, 11:40 am
Default Traction control makes odd noise.
It happens intermittently, but every time I use the car (a 2001). I hear a noise like a solenoid rapidly cycling - it lasts for about two seconds - and the traction control light comes on. It happens only in dry conditions; the traction control seems to work ok in the wet. On one occasion the ABS light came on. Any ideas?
Thanks, Eric
Old 07 Mar 2012, 05:53 pm
Default Re: Traction control makes odd noise.
Hmmmmmm have you done the key dance to see if you're throwing any error codes???
Old 07 Mar 2012, 06:52 pm
Thanks, Eric
Probably one of the abs sensors acting up. try unplugging and replugging them. If that doesn't do it, may need to replace one. Computer codes might tell you witch one.
Old 07 Mar 2012, 10:17 pm
Thanks for the speedy replies. The key thing shows "done" which I guess means all is ok. I'll check the ABS connections this weekend and report.
Eric
Old 08 Mar 2012, 12:20 pm
Similar to my 2001 LE, it was corroded castellated section on one of the wheel hubs. As a tooth (or whatever they are called) had rusted away the sensor thought I had locked the wheel. It would only show up when slowing down slowly.
I had to have the part replaced, cost about £95 using a pattern part, not original. Works fine now.
What else makes grinding noise? 808 Wheels, Tires, Suspension 14 04 Apr 2012 04:21 am
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Traction Control? RaineMan General Turbo Discussions 3 21 May 2011 01:04 am
traction control noise??? mine doesn't do it! pingber General PT Cruiser Discussions 7 13 Jan 2003 11:18 am
traction control noise?? mine doesn't do that! pingber Tech & Performance Forum 1 01 Jan 1970 12:00 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
