Power Steering Failure at Low Revs
Old 08 Mar 2012, 03:28 pm
McBest's Avatar
Default Power Steering Failure at Low Revs
Hi All,
I got my 2007 PT Cruiser Cabrio 2.4 petrol (UK model) in early December 2011. The power steering developed a fault around Christmas and I just got the car back from the garage after leaving it with them in early January! Apparently, there were delays with the parts. It has 24,000 miles on the clock.
Anyway, the problem is still occurring. When the car is warmed up and idling, the power steering seems to stop and the steering is heavy. As soon as the accelerator is depressed and revs get above 1, power steering returns. When driving, the steering is fine but when I'm parking or waiting in a line of traffic, the power steering stops.
The garage replaced the power steering pump and when the problem persisted, they discovered swarf in the system so replaced the steering rack and needed to install a second new pump - the problem continues.
All this work has been done under warranty and I have now got an appointment with an official Chrysler garage who will do a diagnostic check.
Has anyone had this problem? What could be causing the problem?
I read online about a need to clean or replace the reservoir which has a fine mesh filter inside. The garage said they completely flushed out the system when they were replacing the pumps so would this eliminate the reservoir being the problem?
Any advice gratefully received!
Jeff
Old 08 Mar 2012, 05:29 pm
UptownSport's Avatar
Default Re: Power Steering Failure at Low Revs
Gee, no idea.
Sounds like they did what one would expect them to do in that situation.
Things really hard to steer with no power steering, eh?
Old 08 Mar 2012, 07:50 pm
What about the screen in the reservoir?
Old 09 Mar 2012, 03:25 pm
Talking Re: Power Steering Failure at Low Revs
Loose belt?
Old 09 Mar 2012, 05:58 pm
Originally Posted by NightWing View Post
Loose belt?
Thought you would have heard that? But that is always the best outcome.
Tags
pump, steering
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
No power steering. monitor51 Tech & Performance Forum 11 20 Dec 2010 08:47 pm
Power steering switch failure Sue Tech & Performance Forum 1 09 Jun 2009 11:00 am
Complete Intermittant Power Failure lcann25 General PT Cruiser Discussions 4 01 Nov 2008 12:01 pm
Engine Just Dies. Total Power Failure BillStephenson Tech & Performance Forum 2 07 May 2007 02:00 pm
