Adjust/Aim '06 Fog Lights??
Old 12 Mar 2012, 06:42 am
Default Adjust/Aim '06 Fog Lights??
-Just replaced both of mine due to damage-just bolted in the new replacements and at night they seem aimed too low.......how far should they project out? doesn't seem to be any side-to-side adjustment....
Old 12 Mar 2012, 09:33 am
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
Default Re: Adjust/Aim '06 Fog Lights??
There is no adjustment on the fogs, they just bolt in with two bolts.
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Old 12 Mar 2012, 12:29 pm
Wink Re: Adjust/Aim '06 Fog Lights??
-On my '06 GT the lights themselves are held in by 3 screws each, and there IS a screw for adjustment up and down-evedentally the 3 mounting screws hold the bracket to the car and the LONG screw is adjustible to either lower or raise the light-I'm just trying to find out what is common as far as how far out they should shine.....
Old 12 Mar 2012, 01:16 pm
rcktpwrd's Avatar
ChromeNut has provided lots of useful documents on how to repair our PT's. He has the headlight adjustment procedure but I didn't see the foglight procedure specifically. But it is mentioned in the document. Basically measure from the ground to the center of the lamp, then subtract two inches from that and make a mark on a wall 25 feet away and aim the light up or down to that mark.
http://www.hugginsnet.com/ptcruiser/...pAlignment.pdf
Joel
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Adjust the speedometer? Calab Tech & Performance Forum 3 09 Sep 2011 02:15 am
Ebrake adjust Semp0560 General PT Cruiser Discussions 2 15 Aug 2011 12:56 pm
How To Adjust Idle?? tcr1016 Tech & Performance Forum 5 07 Sep 2010 07:45 am
Lever to adjust seat angle broken Edwin Astacio Interior Accessories Forum 12 18 Nov 2009 12:38 am
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
