2001 PT overheating issues.
Old 15 Mar 2012, 10:16 am
Default 2001 PT overheating issues.
I have recently replaced my rad, harmonic balancer, belts, and thermostat.
Since the belts and balancer have been replaced there is a steady squealing sound coming from that area. As well the car continues to overheat, but it is fine when I turn the heat on. Is it possible they used the wrong thermostat?
As for the squealing could it be the water pump?
Thanks for any help.
PS It is getting a little warm here to be cruising with the heat on.
Old 15 Mar 2012, 01:49 pm
UptownSport's Avatar
Default Re: 2001 PT overheating issues.
That'd be classic fans not working- Does it overheat at speed (45MPH)?
Ensure squealing accessory belts (spray brakleen on them) and NOT
anything inside the timing cover.
Old 15 Mar 2012, 02:04 pm
Dill's Avatar
Just replaced my radiator fan yesterday. No more overheating! U can get a fan on ebay for $60
Old 16 Mar 2012, 11:07 am
rcktpwrd's Avatar
readjust the tension on the alternator belt, it's probably loosened up a bit.
Joel
www.rcktpwrd.com
Old 17 Mar 2012, 03:12 pm
whiteclaw's Avatar
How does one do that may I ask?
I think I need to know these things, but have no idea where to go look.
Old 17 Mar 2012, 03:41 pm
This is for the US 2.4 2001 model-
Here you can see the alternator-
Lower Left center there's a the securing nut- 15mm wrench size IIRC
Loosen this first
upper right center is the aduster bolt- 'tighten' it to put tension on belt.
There's also the pivot bolt below, center left (you can see alternator belt, too) you'll need to loosen.:
It's behind this cover (if a shop hasn't already 'left it off'
Very straightforward, but not fun!
Old 19 Mar 2012, 05:50 am
Originally Posted by angelineB View Post
I think you just have to replace the radiator.
FWIW, the very first sentence in the original post states the radiator was just replaced
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Overheating and Other Issues deprivedwriter Tech & Performance Forum 8 16 Aug 2015 03:31 pm
Overheating issues jkdrummer Tech & Performance Forum 3 25 Jun 2012 09:36 pm
'08 AC and overheating issues --- HELP! Mitsukai Tech & Performance Forum 5 08 Aug 2011 11:59 am
Continuing with the overheating issues... 2k1PT General PT Cruiser Discussions 21 20 Sep 2010 06:44 am
really crazy overheating issues... clsd1980 Tech & Performance Forum 4 03 Aug 2010 03:42 pm
