whats the best way to start engine?
Old 15 Mar 2012, 01:11 pm
Send a message via MSN to niel
Default whats the best way to start engine?
Just a simple question.... whats the best way to start the pt cruiser engine? to let the gas pump work for a seconds and the crank? or just to crank the engine right away?
"I AM THE DIGITAL SIGNAL PROSESSOR"
Old 15 Mar 2012, 01:20 pm
Default Re: whats the best way to start engine?
i've always just turned the key to start. never had a problem.
Old 15 Mar 2012, 01:24 pm
Dill's Avatar
With a key
Old 15 Mar 2012, 01:25 pm
Dill's Avatar
Realistically i usually swotch to the on position first for a few seconds before turning the car all the way on. But your car should be primed with fuel already so either way should in effect work
Old 15 Mar 2012, 01:30 pm
rcktpwrd's Avatar
either way should work... but it is typically best to turn the key to the run position for a few seconds to allow the fuel pump to prime and all the electronics to power up then crank it up.
Joel
www.rcktpwrd.com
Old 15 Mar 2012, 01:59 pm
UptownSport's Avatar
Volkswagen had a tag in their early fuel injected cars (as people were used to carburetors):
1. Sit down
2. Buckle up
3. Turn Key
Thought it was kinda funny so remembered it
Old 15 Mar 2012, 02:57 pm
Follow the manufactures instructions. Or as Uptown said.
Old 15 Mar 2012, 08:22 pm
mdfrodolives's Avatar
I just turn the key and it starts. Most modern cars have a check valve to keep the fuel in the lines.
Tim
Old 15 Mar 2012, 10:08 pm
When stripping cars, eventhough gastank has been long drained, there's still pressure in fuel rail after weeks of sitting!
Amazing.
Old 16 Mar 2012, 12:08 am
Wow thanks guys for all your reply's .... Yes I always turn the key right away but was seen videos on YouTube of random domestic and exotic cars and most of the owners let the fuel pump work and then crank thank you guys
Engine will not start decoyboy Tech & Performance Forum 6 15 Mar 2012 09:02 pm
engine won't start thinking it's a bad ECU luckybadazzboy Tech & Performance Forum 23 24 Mar 2011 12:12 am
Engine start button careyk General PT Cruiser Discussions 13 26 Aug 2008 08:45 pm
PT Cruiser Engine Start Up skylight PT Cruiser Videos 0 28 May 2008 07:48 pm
engine start button Musicman Exterior & Interior Styling 6 31 Dec 2004 12:24 am
