Timing belt kit wanted
Old 18 Mar 2012, 10:05 pm
Default Timing belt kit wanted
Hi
I just purchased a non running 2002 PT that has a broken timing belt. Is there a place to buy a complete timing belt kit for a 2002 PT?
What is a good brand, not too interested in saving $20.00 up front only to have something fall apart in 20K. So I think from what I have read here i should replace water pump, thermostat, timing belt, and idler.
Old 19 Mar 2012, 12:39 am
Default Re: Timing belt kit wanted
try rockauto.com. they have several kits to choose from. not sure, but i think you don't want the kit with the gates water pump.
i'm sure someone with more knowledge will chime in.
and while you're at it you might as well replace the serpentine and alternator belts.
Old 19 Mar 2012, 07:25 am
ROCKETMAN8060's Avatar
Timing belt time!!!
ROCKETMAN8060
Old 30 Mar 2012, 10:10 am
if you're worried about longevity then get one at a dealer then you'll have an OEM part
Timing Belt? itzcorky Tech & Performance Forum 7 12 May 2011 07:59 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:19 pm
