2004 PT PO301 code issues
Old 25 Mar 2012, 10:59 am
Default 2004 PT PO301 code issues
Hello, I have been having a lot of issues with this code (po301) I have replaced all wires, coil pack, plugs and now the injector for number 1 cylinder. It keeps coming back within 24 hours of repairs. What else can be causing this missfire in cylinder 1?
Old 19 Apr 2012, 11:33 pm
ptcruisindad's Avatar
Default Re: 2004 PT PO301 code issues
Hello, Sorry for the long time to reply to you. I am having the same problem with my '05 PT Cruiser. I'm getting a PO 301 code. I tried switching the no.1 plug and the no. 4 plug wire. it fixed the problem for about a day, and it started doing the same thing all over again, and got a PO 301 Code. I checked the plugs, and they are fine . I am told that the Coil pack on the PT's go bad ,and the time they go bad veries, so you might want to experiment ,as I did by switching the plug wires and seeing if the problem code travels with it to the No. 4 cylinder,thaen check the condition of your plugs,and then more than likely it's probably the ignition coil that sits on top of the valve cover. once you remove the exhaust manifold blocking the valve cover it's a piece of cake to get to! you can also take it to an auto part store and have them test it for you. Pep Boys sell a BWD ignition coil for around $67.00 a bit cheaper than o'reilly's and Auto zone. Good Luck!
Old 20 Apr 2012, 07:42 am
ptcruisindad, your the first to come to the forum with a bad coil pack. In all the other problems with a cylinder misfire code, it's always come down to something else other than the pack. I'm not saying there isn't a bad one, and you proved that, but 9 out of 10 times the misfire is something else.
2004kc, like Dad said, move the plug or wire to a different spot and see if the code changes. If not, you either have a vacuum leak on the manifold somewhere or you might have an internal problem and a compression check is needed. Owners have found small cracks along the seam of the upper manifold around the area of the offending misfire or where the upper and lower parts of the manifold come together.
2004 PT cruiser having engine light issues echillie1 General PT Cruiser Discussions 20 30 Dec 2011 12:19 am
2004 PT GT Stalls with P0340 code ron2004gt General Turbo Discussions 18 17 Apr 2011 06:46 pm
2004 PTC GT code Po340 MidloPTCJim Tech & Performance Forum 3 25 Oct 2010 04:22 pm
2004 Issues - Don't want to give the car up..but... wndyeliza General Turbo Discussions 7 23 Sep 2010 12:30 pm
2004 PT - P0071 Code tjk3030 Tech & Performance Forum 6 08 Feb 2009 08:48 pm
