2006 PT Cruiser bucking when accelerating + no check engine codes
Old 26 Mar 2012, 07:58 am
Default 2006 PT Cruiser bucking when accelerating + no check engine codes
Hi all,
Been having an intermittent problem that is getting worse so I need some help.
A few weeks back, I went out to my car and the engine wouldn't turn over. It sounded like the engine was just about to catch, but it would then sound like it was repeatedly trying to catch. Power came on (radio, lights, etc.) but no start. I waited about an hour, had my sister in law come to give me a jump, but as soon as she arrived, I tried one more time and the car started, with the engine light coming on. I got the car home and checked the codes. No codes.
So I took it to my mechanic who looked it over, check active and stored codes, checked my wiring, everything. Couldn't find anything. Told me it could be either my TPS sensor or something else, which isn't coming to me at this moment. Told me that I could get either one changed, but since they don't know exactly what it is, that I should wait until it gets a bit worse so they can pinpoint it and not have me waste money.
So I continued along and every so often, my engine light comes on, I check codes, and nothing comes up. Still getting just "done". Just this past weekend I acclerated quickly on the highway and my car started bucking with the check engine light coming back on. It would buck around 2-3 rpm with the needle going up and down. I pulled off and checked codes again(!) and nothing. I drove home, coasting around 60mph with no bucking.
The car hasn't done it again until this morning when I my light came back on (guess what code I got...none) and bucked a little bit.
Any ideas on what it could be? I've checked around this forum for a while and find problems that share my symptoms, but every one else is getting codes, so they can narrow it down. I'm at my wits end. Just want my car fixed so I can stop playing russian roulette everytime I need to go somewhere.
Thanks again.
Old 26 Mar 2012, 08:51 am
VNT's Avatar
VNT VNT is offline
Default Re: 2006 PT Cruiser bucking when accelerating + no check engine codes
Sounds to me like the cam position sensor.
I would go the local mopar store, buy a new on and slap it in.
10 minute job, save the old one but I bet that is your problem.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 26 Mar 2012, 09:48 am
I agree with VNT. But I must ask, are you absolutely sure that you moving the key quickly enough for the codes to be displayed?
Old 26 Mar 2012, 12:23 pm
He said he checked the codes and was just getting "done". If he gets "done" then he's doing it right.
You say you're "at your wits end" and you're "tired of playing russian roulette". Those feelings will continue until you "do something" to fix it.
Replace the cam position sensor with a dealer supplied new one. No aftermarket.
Jerry
Old 26 Mar 2012, 08:59 pm
Didn't read the OP very carefully. Wpp is right also. Change the CPS...
Check engine light is on, but no codes? wilakers24 Tech & Performance Forum 2 05 Jul 2010 10:47 pm
2006 PT Cruiser Engine Light Codes animepunk2103 Tech & Performance Forum 1 08 May 2010 12:21 pm
Engine Light + Bucking When Accelerating kalyhan Tech & Performance Forum 9 06 May 2010 10:06 am
Engine check on / Codes Krzysztof General PT Cruiser Discussions 1 16 Apr 2007 09:37 am
Check engine light on - & NO CODES?!?! CraigO Turbo Performance 9 20 Dec 2003 02:42 am
