mushy brakes
Old 26 Mar 2012, 10:07 am
Default mushy brakes
replaced brakes & rotors couple of weeks ago ,now when you push on the brakes sometimes they hold through two to three stop and goes then they kind of hold and then just let go ,bled the front and back yesterday doing better but not as frequint
Old 26 Mar 2012, 10:12 am
Default Re: mushy brakes
You have to remember - anytime you replace brake pads and/or rotors, you have to adjust your calipers to allow the pads to slip out. Then you have to adjust again to get the new pads in and slip it back on the rotor. When doing this, you're moving fluid through the hoses and reservoir. First rule of thumb when working on any hydraulic system of any type: ANY movement of fluid through the system when NOT under power will require the system to be bled!
Personally, I'd never touch my brakes without following up with a good bleed. It's a safety thing, my wife calls me "safety man" all the time because of stuff like this.
Old 26 Mar 2012, 10:57 am
SHOULD I ALSO BLEED THE MASTER CYLINDER
Old 26 Mar 2012, 02:03 pm
UptownSport's Avatar
What you're saying is the pedal is dropping?????
If so, you either have a leak or bad master cylinder.
Old 26 Mar 2012, 02:44 pm
rcktpwrd's Avatar
Also when bleeding the system you can't do the rear then the front like the old way. The PT has a diagonally split brake system, so the left front and right rear are one side and the right front and left rear are the other side if the system.
The exact bleeding procedure is in the forums somewhere...
Joel
www.rcktpwrd.com
Old 26 Mar 2012, 05:05 pm
If I were having your symptoms I would bleed the master cylinder first, then the left rear, then the right front, then the right rear and finally the left rear.
Jerry
Old 23 Apr 2014, 02:44 pm
+1
Can anyone point me towards the brake bleeding procedure posted on the forums?
I recently replaced the rear drums, shoes and wheel cylinders. Then I bled it classically, rears to fronts without master cylinder, and now it feels worse than before the new parts.
-Andrew
2006 Inferno Red Limited with the Turbo
Old 27 Apr 2014, 02:49 pm
Jerry
What is the order for brake bleeding?
Is there a way to bleed the master cylinder while it is in the car?
Where is the forum instructions for bleeding the brake? I couldn't find it.
I used the search function to save you guys the time reading a new thread.
Will someone please help me?
-Andrew
Old 27 Apr 2014, 06:02 pm
Originally Posted by HanaTurbo View Post
+1
-Andrew
Look at the post right before yours from wwpptc.........
Old 27 Apr 2014, 06:14 pm
Is this a pt cruiser you are referring to?
brakes... superpug666 Wheels, Tires, Suspension 2 15 Jul 2009 05:08 am
Front Brakes - replaced, and now mushy sifu_scott Tech & Performance Forum 9 21 May 2009 09:05 pm
Bad Brakes Sherri7391 Tech & Performance Forum 14 28 Oct 2005 03:26 pm
Brakes? purple people eater Turbo Wheels/Suspension/Handling 1 23 May 2005 09:05 am
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
