2003 GT Turbo leaking some fluid
Old 26 Mar 2012, 01:49 pm
Default 2003 GT Turbo leaking some fluid
Hi,
I just bought a 2003 GT Turbo, my garage has a slight inclination and every morning I see a patch in the floor in the front, left side. Transparent and no odor, not oily neither; I could say it is water but my car does not have any in the system (the radiator deposit is full of antifreeze). I check the deposits every 3 days with no significant loses. If the car is on a plain surface, it does not spill anything. What it could be?
Old 26 Mar 2012, 02:06 pm
VNT's Avatar
VNT VNT is offline
Default Re: 2003 GT Turbo leaking some fluid
All leaks are visual, get out floor jack and jack her up, put stand under car, take a look.
also put some cardboard under car and see what leaks onto it.
dark= oil
red= ATF
Clear= brake
orange=coolant
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 26 Mar 2012, 04:15 pm
Thank You VNT, I already made the "cardboard test" and it is clear, no odor. Definitely not oil or ATF. It could be Break fluid then, but the leak is in the very front of the car, under the radiator, it doesn't seems a place for break fluid, doesn't it?
Old 26 Mar 2012, 05:07 pm
VNT's Avatar
VNT VNT is offline
I would get underneath and look. It could be water.
Brake fluid, look at the lines and around the calipers and reservoir. Is your reservoir full??
Is yours a manual of auto? If manual could be leaky slave cylinder.
VNT
Old 26 Mar 2012, 06:12 pm
If you got ac they have a discharge line for condensation .
Old 26 Mar 2012, 06:27 pm
VNT's Avatar
VNT VNT is offline
That would be at the firewall, not the front of the car.
To me front would be coolant or trans fluid from the cooler assuming a auto.
VNT
Old 28 Mar 2012, 10:49 am
Thank you all. It's AT, with autostick.
Last night I jacked the car up and I saw it's coolant, is leaking by the drain valve of the radiator. It's a plastic thing, so I tried to tighten it with my hand, I am not sure about using pliers, I dried the floor of my garage, but this morning I see the patch again I saw there's also a small rubber pipe that goes from the bottom of the radiator to somewhere in the AC system (I think) it has moisture also, what you think?
Old 28 Mar 2012, 05:28 pm
VNT's Avatar
VNT VNT is offline
It sounds like your drain cock on the radiator is leaking.
I would buy a gallon of distilled water and a couple gallons of HOAT antifreeze.
Now if you dont need the car, assume worse case you frig it up, get a pair of needle nose pliers, turn the pet cock CCW, it should back out toward you and coolant will come out. then reseat it by turning it CW, it should go in to the radiator as you turn it, you will feel it stop so dont reef too hard on it.
Now if it stops leaking your all set, if not bring it to a dealer and explain what is going on, they may have to order a new drain cock for it.
BTW, you have the distilled water and coolant just in case, but hopefully you can back it out and turn it back in to reseat it and seal it.
VNT
Radiator replaced, now leaking power steering fluid JamesPisanich General PT Cruiser Discussions 3 30 Sep 2011 10:23 am
Transmission fluid leaking and possible lawsuit joeus Tech & Performance Forum 8 20 Jan 2010 12:37 pm
Need for 2003 PT Non turbo VOETOM Classifieds: Want To Buy 3 04 May 2009 04:39 am
New 2003 Turbo BLH1 General Turbo Discussions 6 31 Mar 2004 08:53 pm
Turbo leaking oil 03baggedturbo Turbo Performance 5 09 Dec 2003 09:54 pm
